RPM sender unit
/ RPM sender unit #1
Hayloft
Bronze Member
Western Wash
3520HST
Hi there,
Anybody replaced the RPM sender ?
When first startup my 3520H sticks on really low RPM no matter what throttle is set at. After several minutes, like during warmup, the RPM starts reading normal.
Hmmmm I figured it's likely a sender unit starting to go.
2014 3520H model.
~Regards
/ RPM sender unit #2
The tachometer on the dashboard gets the signal from the alternator. It's a single wire that comes out the back.
You may want to check if the plug is fully seated and without corrosion.
/ RPM sender unit
Hey ptsg,
Thanks for your assist...I'll check that connection out !
Regards
/ RPM sender unit #4
Forgot to add on the other post but if that doesn't work, try wiggling the plugs behind the dashboard.
Might be necessary to pull some covers out though.
/ RPM sender unit
Yep
Got it & will do that.
-Regards
2023 JOHN DEERE 35P EXCAVATOR (A65056)
2023 JOHN DEERE...
1997 FONTAINE FLATBED (A67714)
1997 FONTAINE...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A68183)
1987 Fruehauf MC...
2013 FORD F-150 (INOPERABLE) (A67714)
2013 FORD F-150...
2010 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2010 CHANDLER TRI...
