RPM sender unit
/ RPM sender unit #1
Hayloft
Western Wash
3520HST
Hi there,
Anybody replaced the RPM sender ?
When first startup my 3520H sticks on really low RPM no matter what throttle is set at. After several minutes, like during warmup, the RPM starts reading normal.
Hmmmm I figured it's likely a sender unit starting to go.
2014 3520H model.
~Regards
/ RPM sender unit #2
The tachometer on the dashboard gets the signal from the alternator. It's a single wire that comes out the back.
You may want to check if the plug is fully seated and without corrosion.
/ RPM sender unit
Hey ptsg,
Thanks for your assist...I'll check that connection out !
Regards
/ RPM sender unit #4
Forgot to add on the other post but if that doesn't work, try wiggling the plugs behind the dashboard.
Might be necessary to pull some covers out though.
/ RPM sender unit
Yep
Got it & will do that.
Thanks
-Regards
2009 FORD E-150 CARGO VAN (A66091)
2009 FORD E-150...
2010 Rhodes AS3575-3 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A66736)
2010 Rhodes...
2021 JCB 3TS-8T TELESKID (A65056)
2021 JCB 3TS-8T...
2015 JOHN DEERE 544K WHEEL LOADER (A65056)
2015 JOHN DEERE...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A67714)
TWO PALLETS OF HYD...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
