RPM sender unit
/ RPM sender unit #1
Hayloft
Western Wash
3520HST
Hi there,
Anybody replaced the RPM sender ?
When first startup my 3520H sticks on really low RPM no matter what throttle is set at. After several minutes, like during warmup, the RPM starts reading normal.
Hmmmm I figured it's likely a sender unit starting to go.
2014 3520H model.
~Regards
/ RPM sender unit #2
The tachometer on the dashboard gets the signal from the alternator. It's a single wire that comes out the back.
You may want to check if the plug is fully seated and without corrosion.
/ RPM sender unit
Hey ptsg,
Thanks for your assist...I'll check that connection out !
Regards
/ RPM sender unit #4
Forgot to add on the other post but if that doesn't work, try wiggling the plugs behind the dashboard.
Might be necessary to pull some covers out though.
/ RPM sender unit
Yep
Got it & will do that.
Thanks
-Regards
2015 FREIGHTLINER CORONADO 122 SD (A67714)
2015 FREIGHTLINER...
Gehl RS6-34 (A64119)
JOHN DEERE 5090 EL TRACTOR (A65057)
JOHN DEERE 5090 EL...
2016 Chevrolet Impala Limited Sedan (A66738)
2016 Chevrolet...
1 PALLET OF CATALYTIC CONVERTS (A66091)
1 PALLET OF...
2016 CHEVROLET IMPALA CAR (A66091)
2016 CHEVROLET...
