Rounded off drain plug
/ Rounded off drain plug #1,881
Tomorrow is the day to celebrate independence for our country. Perhaps the drain plug can also celebrate and be free!!
/ Rounded off drain plug #1,882
Too bad its freedom will end up in the scrap metal pile or the garbage can.......
/ Rounded off drain plug #1,883
what can I say, I am blind as a :bat: with out them
/ Rounded off drain plug #1,886
I think he gave up, and will just replace the transmission when it wears out from dirty fluid!.:eek:
I think that he had it out by the second page, but is keeping the thread going for the entertainment value... Ours, not his.
/ Rounded off drain plug #1,887
correct its been fixed a LONG time ago
/ Rounded off drain plug #1,890
The betting line on whether the plug will ever be removed by the OP is changing quite a bit now.
Plug out.
End of an era.
Go home folks.
/ Rounded off drain plug #1,893
Thanks for following up Kando!
/ Rounded off drain plug #1,894
How can that be? Everyone said Kando could not do it. Do we have a winner on the suggested post that was followed?
Threads look clean.
/ Rounded off drain plug #1,895
Gotta ask...
What did the fluid look like? Any metal? Any sludge? Water?
/ Rounded off drain plug #1,897
And just like that, the world was whole again. Things make sense again.... Now if we could just figure out those pallets... :) Good job Kando !
/ Rounded off drain plug #1,898
How did you get room for the drill and extractor?
Bruce
/ Rounded off drain plug #1,899
Threads look clean.
I skipped over several posts when pipe wrenches were being discussed again for the 100th time but I don't recall anyone suggesting ease-out.
Now,I need to put new tires on my gravity wagon but I can't loosen one of the lug nuts.:rolleyes:
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
2019 Ford F-250 Ext. Cab Pickup Truck (A61573)
2019 Ford F-250...
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
