Rounded off drain plug
/ Rounded off drain plug #1,762
Now we have the underlying cause; rusted from the inside jamming up the threads. Oil floats on top of water, and the drain is the low point; so,wouldn't take much free water to create rust especially with a good dose of the products of combustion which are acidic. Kando didn't have a ghost of a chance on this one.
--------------------------------Ron
"with a good dose of the products of combustion which are acidic." In the transmission?
/ Rounded off drain plug #1,765
A pipe wrench grips much tighter vice grips. Had the op skipped the vice grips and the channel locks and went straight to the pipe wrench and he knew how to use a pipe wrench the plug would be out already.
He did skip the vice grips and bought a new pipe wrench on the suggestion of several members.
And just for the record, the more "rounded off" the work object is the better the pipe wrench is going to work. After all it works perfectly on round pipe and round pipe fittings now doesn't it?
So instead of getting the plug out, he first needs to bung it up more? I have yet to see a nut or bolt which actually "rounds" when the corners wear off. Usually they become more oval shaped.
^^^^^^ What he said !!!
Since we have to round it off first, why not try the one tool which he hasn't used? If nothing else, it will make the plug so that the pipe wrench works. :D
I still would opt for the "call for help"; preferably somebody with a Mig, who knows how to use it. I don't remember if Kando said he was the last person to change the fluid; but I can't help wondering if somebody might have used some good old fashioned "Loctite Red" on it.
/ Rounded off drain plug #1,766
Kando, we are half way through the Memorial Day weekend. Times a wastin :drillsergeant:
/ Rounded off drain plug #1,767
That is until it grinds enough off and gets so small it just breaks off. Then; back to drilling it out.
Ron
/ Rounded off drain plug #1,768
"with a good dose of the products of combustion which are acidic." In the transmission?[/Q
Cut us old guys some slack; we have a hard time remembering all the stuff we read through 1775 posts. Who knows, the additives to transmission fluids may add acid to the water also or is Kando's tractor so old it uses 30 or 40 weight motor oil for transmission oil. Some of the old farm tractors used the motor oil sump as source for hydraulic fluid. Helped a guy once that had one of those. He claimed that the thicker the oil got the better the 3 point worked. He had a FEL for it but never put it on the trator.
/ Rounded off drain plug #1,772
And my happy divorce anniversary right after that!
/ Rounded off drain plug #1,773
The 2 year anniversary of this thread isn’t that much longer...
/ Rounded off drain plug #1,774
I asked my doctor about this stuck plug and his thought was it's a simple case of Hirschsprung's disease. It's not as uncommon as you think, and some people have been stopped up for years...so this may take a while yet.
His recommendation was finding a good Gastroenterologist.
When that plug finally comes out, the relief will be indescribable.
It has the makings of a great movie...slow at first, but what a climax!
/ Rounded off drain plug #1,775
1 glass 8 oz. every ten minutes until the one gallon of Go-Lytley is totally consumed.
Guaranteed to spit that plug out by end of day.....:cool2:
/ Rounded off drain plug #1,776
OMG. That brings back a lot of really bad memories. I have never felt so bad as that day in my life.
/ Rounded off drain plug #1,777
They do not want any sludge in the pipes when the send the camera up there. :shocked:
/ Rounded off drain plug #1,779
I know but when that stuff kicked in I was on the trot every 5 to 7 minutes and for what seemed like hours. As soon as I'd return from the dunny I was off again... thankfully more than one bog-roll was 'standing-by'.
My arse was dry heaving by the end of it.
/ Rounded off drain plug #1,780
I had the doctor videotape our procedures which we watch on our wedding anniversary.
(2) 15 Gallon Sprayers, 25 Gallon Sprayer, Honda Pressure Washer, Wheel Barrel (A64119)
(2) 15 Gallon...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
2010 Mercury 15HP Tiller Outboard Boat Motor (A61574)
2010 Mercury 15HP...
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
