Rounded off drain plug
/ Rounded off drain plug #1,952
The head of the plug was cut off before we drilled through it, after drilling we chiseled away the rest and cleaned it up flush to the pan. After that tapped the easy out into the hole and started turning. Came out smooth after all that.
What did you use to cut off the plug?
/ Rounded off drain plug #1,953
I'm a bit late, but thank you Kando for providing us with the entertainment for the last year +.
:thumbsup:
/ Rounded off drain plug #1,956
Epic thread.
Yeah, I skipped a page or two.
Say it is not so! There is a lot to learn in this thread, if you ever have a stuck drain plug this is the thread to research. Thesis material it is :thumbsup:
/ Rounded off drain plug #1,958
/ Rounded off drain plug #1,960
Maybe, if you figure out how difficult it will be to get that cross bar back in place and if any additional help or tools will be needed.
I have a 3' pipe wrench, mention long ago, that should work. Proper tool for the proper job.
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
