Rounded off drain plug
/ Rounded off drain plug #1,701
I hope Kando gets the drain plug out soon. If not this thread is going to turn into a lot of pictures of people standing on knipex, channel locks, and other various tools just to show that the tool can support them. Sorry I couldn’t resist saying that, but that’s the first thing that popped in my head when I saw the 2 pictures of people standing on pliers.
Yes, but I think the point being made was there are some among us who feel those particular tools (or a correctly sized pipe wrench) will continue to maintain grip on the plug regardless of the forces applied to it.
/ Rounded off drain plug #1,702
Besides all the goofy posts (and post count bed wetters :D)...most are missing the big picture and not realizing that it's the condition of the exposed plug that is the issue...the gripping power of any of the applicable tools is a moot point...reducing the mass (to shape it) of the exposed plug end is only going to increase the odds if it shearing off the bulk of the plug...
Again (and with others that have said the same)...I would use an appropriately sized pipe wrench on the threaded part of the plug...I understand that there is an estimated (by the OP) 1/4" of original plug threads...but properly applied with the right sized wrench it is a viable approach if done judiciously...
/ Rounded off drain plug #1,703
With the aid of heat. Ten seconds with an oxy-acet torch or an induction heating tool like dragoneggs posted. NOT a slow heating propane torch or similar.
/ Rounded off drain plug #1,704
For anyone to take this seriously, could you include a picture while standing a similarly applied pipe wrench? Otherwise it could be construed as just another goofy post. :confused2:
/ Rounded off drain plug #1,705
That, and a pipe wrench and that thing would be out in seconds, or I would know the reason why.
/ Rounded off drain plug #1,707
Are you suggesting that he should have tipped the tractor on it's side and stood on the pipe wrench a long time ago? :D
I'm really shocked we don't have a Texas Aggie jumping in on this one.
This is the perfect undergrad project!!!:D
/ Rounded off drain plug #1,709
Back to the beginnings:
- Kando has already used a pipe wrench on the plug flats and succeeded in grinding away all the meat of the square wrench flats
- There is a cross member that prevents getting a straight angle on the plug with any tool
- Unless a pipe wrench can get the full flat of the jaws on the culprit item, and especially working on an angle, the grinding action is very effective at reducing the plug cross section more
- The pan with the plug in contention is still full of liquid that tends to absorb any attempt at using heat
So; I still contend drilling it out is the best solution, after you unbolt or cut the offending cross member out of the way. Drill a small hole first to drain out the fluid running down your arms. I have already posted a couple ways to effectively accomplish such. If Kando asks, I will repeat those two ideas so he does not have to go on an Easter Egg Hunt for them in 1700+ posts
As I posted elsewhere; "As we are contending with the alligators we tend to lose sight of the original mission that was to drain the swamp".
Ron
/ Rounded off drain plug #1,710
Yes, thesis material :thumbsup:
An excellent summary,Ron but I beg to differ concerning heat. Yes the liquid filled pan will resist heat but only the solid malleable iron plug needs to be heated. I still maintain that it would get red hot with an oxy-acetylene torch in well under 10 seconds.
During the next 30 seconds the torch can be extinguished, placed safely to one side and the plug removed with a suitable gripping tool (small pipe wrench, Knipex or whatever.)
Your method of drilling will also work, but I tend to try the easier methods first.
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
2007 Ford Crown Victoria Sedan (A59231)
2007 Ford Crown...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
DEUTZ MARATHON...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
