Rounded off drain plug
/ Rounded off drain plug #1,051
I work 2nd shift 7 days a week, it's cold outside and I'd have to bring the tractor out of the barn to have a suitable workspace with enough light to see.:thumbsup:
Beyond that I've been tinkering on the 5000 i got. Changed the temp sender, coolant, engine and trans oil (water in the trans, eck) and next is replacing the exhaust manifold and muffler.
My vote is to have a mechanic or plumber acquaintance stop out and remove it. Until you've done it, the whole process is foreign and just invites you to dig a deeper hole. We've all been there and once you watch it being done you'll be a pro.
/ Rounded off drain plug #1,052
What I was told over 60 years ago in high school shop class, was with the pressure point farther up the moveable jaw, it is more likley to break the jaw:
View attachment 582643 View attachment 582644
True. But pulling backward as in the 2nd pic tends to open the jaw slightly as the wrench flexes causing it to slip easier, rounding the head at a lower delivered torque.
/ Rounded off drain plug #1,053
/ Rounded off drain plug #1,055
Held like the first picture in your right hand it’s easily adjustable. Held like the second picture it’s kinda clunky. IMG_0876.JPGIMG_0877.JPG
/ Rounded off drain plug #1,057
Digital gauges and digital calipers especially ones that see infrequent use are always dead when you need them.
/ Rounded off drain plug #1,058
If this plug does end up getting welded out what kind of welder should we use. I’d probably use my mig so what shielding gas would be optional and should we use flux core. After all these decisions are made and assuming we have decided in the type of plug which sealant is best?
/ Rounded off drain plug #1,060
How about tire pressure gauges? Stick, dial, digital, oh boy!
You just dont seem to be properly prepared to do any repair work. Tools, shop, lighting, etc...Have you considered a nice apartment downtown? :p
2018 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2018 CATERPILLAR...
Giyi 44" Excavator Rake w/ Shank (A60463)
Giyi 44" Excavator...
4ft Mini Skid Quick Attach Rotary Cutter (A61307)
4ft Mini Skid...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
Pat's QH and hydraulic top-link.
Pat's QH and...
Location Info Please
