Rounded off drain plug
/ Rounded off drain plug #1,061
Nice. I love those old Fords and am still toying with the idea of bringing my father's old gas 4400 (industrial) home. My brother keeps saying that we should sell it; running, we'd be lucky to get $4000 out of it. In current condition, it hasn't even been started in 4 years we'd be lucky to get a grand for it.
Either way it's worth more than that to keep around for the occasional use when I need a bigger tractor; maybe I'll put the cab on and keep it for plowing.
Keep the 4000 !!!
My 3400 TLB is 49 years old ....and I will NEVER part with it!
/ Rounded off drain plug #1,062
Digital gauges and digital calipers especially ones that see infrequent use are always dead when you need them.
Thats the problem I have with my digital calipers. I like the digital feature, but this set stays in the Ham Shack and see infrequent use. Every time I need them the battery is dead. I have gotten to the point of just taking the battery out. My dial calipers never let me down. :)
/ Rounded off drain plug #1,063
Don't have digital, don't have dial, do have vernier calipers that are older than old, but never let me down if I can find them. So far they have always been in the last place that I looked.
/ Rounded off drain plug #1,064
And if you found them in the first place you looked, it would have been the last place. Unless you just like to look.
I can't believe that I am still reading this everyday!
/ Rounded off drain plug #1,065
Leave the rounded drain plug in then suck the old fluid out from the filler plug with a pump and hose.
This ought to be good for another 500 replies, especially if the filler gets stripped out also.
/ Rounded off drain plug #1,066
At least you didn’t pull the drain plug out and then realize the fill plug was stuck.
I now have vernier calipers showing on the ads haha
/ Rounded off drain plug #1,068
Good idea, just like it was almost 1,000 posts ago.
I know a lot of people use mityvacs for engine oil and transmission oil change. Could that work here to get the old fluid out?
I've used my little HF $5 hand pump to take a half quart out of my VW when they vastly overfilled it.
/ Rounded off drain plug #1,069
get a dial caliper, and you will toss those verniers in the weeds. (no need to interpolate) The digital is even easier to use, but expect to buy some batteries. Or remember to pull the battery when you are done using it if you aren't going to use it again in months.
Another advantage to the digital is both metric and imperial measurements at the push of a button. Also you can 'zero" on a measurement and tell how much bigger one object is over another without resorting to calculating it out. The tool will do the calculating for you. AND they are cheap.
https://www.amazon.com/VINCA-DCLA-0...ormat=strip&impressionTimestamp=1544634009329
/ Rounded off drain plug #1,070
Digital calipers are always measuring. Only the display turn off.
Bruce
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
Giyi 2WD Mini QA Excavator Arm (A60463)
Giyi 2WD Mini QA...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2019 Ford F-450XL (A60462)
2019 Ford F-450XL...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2001 CHEVROLET C8500 FLATBED TRUCK (A62130)
2001 CHEVROLET...
