Round Balers
/ Round Balers #1
JimWI
Ripon, WI
2003 AGCO ST45
Are there any smaller bale (4x4) round balers that can be run with a 37 PTO HP tractor?
I only make hay on 10-20 acres a season for personal use. Thanks.
/ Round Balers #2
Yes.
CaseIH 8420
MF 1734
Hesston 530
They are all the same baler with different decals and paint.
They make a 39" x 52" bale
Think they called for 30 PTO HP minimum.
You can likely run some 4x4 balers, the NH 630 I run calls for 35 PTO HP. I'd have no concerns making 20 acres a year with it and 37 PTO HP.
/ Round Balers #5
I ran a Vermeer Rebel 5400 4X5 baler with a John Deere 1070 for years. It struggled a little on steep slopes with a full bale but we were baling around 160 acres twice per year. Same tractor ran a New Holland 9 ft haybine just fine if you took your time. That tractor was rated for 39 engine/35 pto HP. You may have better luck finding a 4X5 baler if you are looking used
/ Round Balers #6
Saw a JD 4 x 4 baler go at auction today that would have been perfect for you. Can’t remember the bid but it was low because that size is not popular here.
/ Round Balers #7
We run a Ford 552 (Gehl 1500 in blue paint, makes 5x5 string tied bales) behind our L3830. It gets worked HARD when you are going uphill and finishing a bale, but otherwise it handles it just fine.
Aaron Z
213096 (A64276)
213096 (A64276)
Rake Master CR7-72G (A64119)
Rake Master...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2019 FORD F350 4X4 PICKUP TRUCK (A59912)
2019 FORD F350 4X4...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
