Tiller Rototiller PTO shaft
   / Rototiller PTO shaft #1
Iowachild
NW PA
Kubota B2320HST
I recently purchased a used Simplicity model 1600199, 48" rototiller. This tiller was designed for a 2000 rpm PTO. The fellow I bought it from has changed a drive sprocket and ran it on his BX, but said the 540 rpm never gave him good tine speed, listed as 200 rpm. In his Craiglist ad, he stated he felt ~1000 rpm would be an effective pto speed. As I have a B2320 and the two speed pto, I contacted the fellow and decided to look a the tiller and the rest is history. (And yes, the 960 rpm seems to run the tiller well.)
This long winding road brings me to the point of my post. The prior owner has also added 5" to the pto shaft in order to use it on his BX. My B has larger geometry and although the shaft is "effectively" long enough, I feel it would be safer and have more stability with another 3" of shaft length. The shaft is 15/16" square stock with a halve round grove milled on one flat to keep the joints in proper orientation. I contacted the previous owner again and he stated as he recalls he had to have a piece milled to match. My other option would be purchase a longer shaft, however the tiller end has a 1" round shaft with 1/4" key, not the 1 3/8" six spline and my attempts to locate an adapter have been futile. Any suggestions from the large knowledge pool available here on Tractorbynet?
Thanks for reading and responding if you can!
BTW If I decide adding more length to the shaft is the way to go, I will have a piece milled long enough to cut off the old extension and add the new.
   / Rototiller PTO shaft #2
How about a PTO extension on the tractor? TSC sells them @ $26.99 and adds 4 inches.
   / Rototiller PTO shaft #3
Tractor supply will sell all the parts to make the correct new PTO shaft. Here is a link to the end yoke with the 1" bore. 6N Series Yoke, 1 in. - 0270095 | Tractor Supply Company
Or any good tractor dealer should be able to help.
Also lots of places on Ebay to get PTO shafts of different configurations
Thank you Sam, I missed that searching the TSC site. This seems like the way to go. :thumbsup:
Northern Tool has the best price I have found on the actual shaft!
The yoke and the new shaft are on order and I should be ready to go by the end of the week.:thumbsup:
Thanks again for the advice!
   / Rototiller PTO shaft #6
These guys PTO Shaft and PTO Shields have the best prices I have seen on pto shafts. Call them because I am sure they can get more than they list. (if you go theat route.
And they are a sponser of this forum:thumbsup:
CONIBEAR EQ CO HYD SEED SPREADER (A60430)
CONIBEAR EQ CO HYD...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
UNUSED FUTURE EXCAVATOR THUMB MOUNTING PLATE SET (A60432)
UNUSED FUTURE...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
