Rotary Cutters ??
/ Rotary Cutters ?? #1
sunnyside360
Central PA
JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
Priced out two new 5' rotary cutters at the JD dealer today -- $1250 for an LX5 and $1250 for Frontier RC1060. Which one is best for the money and is the price good? Thanks for your help. John
/ Rotary Cutters ?? #2
The LX series is discontinued. They are (were) actually made by Deere, while Frontier is outsourced somewhere. I have an LX6, and I think it's among the best light duty brush cutters on the market. I would get the LX5 over the Frontier, personally. The price on the LX5 sounds quite good, not sure if the RC1060 price is anything special.
/ Rotary Cutters ?? #3
Does the Frontier brand cutter have a slip clutch or does it have sheer bolts like the LX5?
I'd go for the one with the most features. :)
/ Rotary Cutters ?? #4
Most dealers order an LX4 or LX5 with the slip clutch. Kinda surprised your dealer didn't. Slip clutch is standard on LX6, and I would definitely recommend it over a shear bolt system.
The RC1060 is not identical to the LX5; I think the LX5 is a better design. The LX series also had some super duper paint process for corrosion resistance.
/ Rotary Cutters ?? #5
They are the exact same machines. The gear box on the RC1060 might be a little different but other than that they should be identical. Both should be equipped with a slip clutch also. I would go for the one that said John Deere on it :)
/ Rotary Cutters ??
Both units I looked at had shear pins (no clutch).
Did John Deere also discontinue the MX5??
/ Rotary Cutters ?? #7
The MX series should still be in production and it quite a bit heavier than the LX or Frontier. I have a MX6 and it is built like a tank. It has the heavy duty gearbox, slip clutch, front and back chain guards and double top constructions that gives it a domed effect to repel water and to keep grass, weeds, dirt, etc, from sitting on top. If you store your mower outside, dirt, old grass and weeds on top will cause it to rust out quicker than anything.
/ Rotary Cutters ?? #8
Greensouth, I realize you are a Deere dealer, but the brochures for the LX series and the RC10xx series show distinctly differently shaped cutters. I do not think that the RC1060 is simply an LX5 made by another manufacturer.
For the other poster, yes the MX series are still in production, and are nice heavy duty machines. The clean top deck should make a big difference for ease of cleanup and less rusting.
/ Rotary Cutters ??
I looked at the JD LX5 along side of a Frontier RC1060 and they don't appear to be identical. The designs are a little different and the paint job on the LX5 is definitely much better than the RC1060. They are very close in weight. Looked at a Bush Hog SQ600 today and it looks to be very stout for $950. Might go look at Land Pride tomorrow. Anyone know how the Bush Hog and Land Pride stacks up against Deere LX5?
/ Rotary Cutters ?? #11
I haven't seen Bush Hog products in person, but they're supposed to be good. Land Pride is definitely top notch, but the LX series are also. Locally Land Pride seems to be the most expensive brand around. IMHO Woods BB60 is probably the nicest light duty 5' cutter at any reasonable price, and the LX5 would be, IMHO, about 99.5% as good. I have an LX6 and if it needed replacement I would pretty much flip a coin between getting another one or a BB72 (though most likely I would step up to an MX6 for the extra capacity and sloped top deck).
/ Rotary Cutters ?? #12
I think the Frontier equipment is made by Woods.
/ Rotary Cutters ?? #13
Some Frontier box blades used to be made by Woods. I don't know who makes the RC cutters but I'd be really surprised if it's Woods. IF a dealer has one in stock, the last page of the owner's manual should have a warranty statement that says who the manufacturer is.
/ Rotary Cutters ??
Did some more snooping around today at other dealers for 5' rotary cutters. The Woods Brush Bull BB60 with clutch is $1250; the Bush Hog SQ600 with clutch is $1170; and the Land Pride RCR1860 with shear bolt is $995. Also, the Woods Heritage HSS60 with shear is $1195 and $1495 with clutch. After looking at them all, I think it's coming down to either the Woods BB60 with clutch ($1250) or the Bush Hog SQ600 with clutch ($1170). Any advice on these models and prices would be greatly appreciated.
/ Rotary Cutters ?? #15
I personally just made the same decision on the mowers. I looked at Woods and the Bush Hog brands, both in 6'. I went with the Woods. It had 10 more HP on the gearbox, 75 hp vs 65 hp, and it also had a 5 year warranty on the gearbox. I also like the way it was built better.
/ Rotary Cutters ??
Well, I got the Woods BB60 with slip clutch today and brought her home. Hooked it up to the JD 3720 Cab tractor and made necessary adjustments. Was initially concerned that some ballast weight may have to be added to front but all went well in the test run -- very smooth running and relatively low noise. Many thanks to all who provided input which helped with the decision. Sunny
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
Cat GC25 Forklift (A65579)
Cat GC25 Forklift...
1042 (A60430)
1042 (A60430)
2023 Bobcat T64 (A64126)
2023 Bobcat T64...
60 Traffic Cones (A65579)
60 Traffic Cones...
