Rotary Cutter ROTARY CUTTER
/ ROTARY CUTTER #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I have a woods 72" RC. Our ground is uneven with ups and downs. Tractor goes up a small mound, RC goes down and vice versa when tractor descends a mound. Is there a good way to have the RC follow the terrain better??
/ ROTARY CUTTER #2
Yes,use a length of chain instead of toplink[heavier chain,with connectors of some kind on each end that your pins that hold top link on go through],set it up the height you want to cut and leave a little slack in chain,won't be able to pick it up as far,and be aware of the fact that if front of hog catches ground or a stump or something rear wheel could come up,so I 'd just do this on fairly known ground with height set up to about 6 inches or so. Just try it and play with it a little and you'll know why I've been cutting like that for 7-8 years now.
You don't even need a top link except to raise it.
/ ROTARY CUTTER #3
A shackle will work for the connection. I have a bunch of these in different sizes.
/ ROTARY CUTTER #4
Do you have the float set up right on the toplink? Check your manual for the correct setup or post a picture of your setup for some feedback. There should be some float for valleys and mounds or damage can occur.
/ ROTARY CUTTER
So basically a length of fairly heavy chain as long as typical toplink length with clevises on both ends to replace toplink. Sounds easy enough. Thanks.
/ ROTARY CUTTER #7
Thats right,make it longer than top link by a bit,you can adjust it by just moving clivis to next link. Play with it a little on smooth ground,try just running with out top link[or chain, a little so's you'll know whats going on.
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
Quick Attach Backing Plate (A65579)
Quick Attach...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
UTILI TOUGH 48" RAKE (A64277)
UTILI TOUGH 48"...
2014 Talbert T4-55CC-HAG-T1, 55 Ton Detach Lowboy (A62679)
2014 Talbert...
