Rotary Cutter ROTARY CUTTER
/ ROTARY CUTTER #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I have a woods 72" RC. Our ground is uneven with ups and downs. Tractor goes up a small mound, RC goes down and vice versa when tractor descends a mound. Is there a good way to have the RC follow the terrain better??
/ ROTARY CUTTER #2
Yes,use a length of chain instead of toplink[heavier chain,with connectors of some kind on each end that your pins that hold top link on go through],set it up the height you want to cut and leave a little slack in chain,won't be able to pick it up as far,and be aware of the fact that if front of hog catches ground or a stump or something rear wheel could come up,so I 'd just do this on fairly known ground with height set up to about 6 inches or so. Just try it and play with it a little and you'll know why I've been cutting like that for 7-8 years now.
You don't even need a top link except to raise it.
/ ROTARY CUTTER #3
A shackle will work for the connection. I have a bunch of these in different sizes.
/ ROTARY CUTTER #4
Do you have the float set up right on the toplink? Check your manual for the correct setup or post a picture of your setup for some feedback. There should be some float for valleys and mounds or damage can occur.
/ ROTARY CUTTER
So basically a length of fairly heavy chain as long as typical toplink length with clevises on both ends to replace toplink. Sounds easy enough. Thanks.
/ ROTARY CUTTER #7
Thats right,make it longer than top link by a bit,you can adjust it by just moving clivis to next link. Play with it a little on smooth ground,try just running with out top link[or chain, a little so's you'll know whats going on.
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
ASSET DESCRIPTIONS & CONDITION (A59914)
ASSET DESCRIPTIONS...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2015 KENWORTH T880 KILL TRUCK (A65643)
2015 KENWORTH T880...
Behlen Grain Bin Aeration Fan (A65640)
Behlen Grain Bin...
