ROPS
/ ROPS #1
valkyrie9901
Adrian, Michigan
Kubota BX-25D
I have NEW BX-25D and I have noticed the ROPS transmits noise from the hydraulic pump and engine more than my old BX-2200. I was wondering since it is hollow would drilling an 1/8th inch hole and filling it with expansion foam used to seal cracks stop the noise transmitting through the hollow tubing? ..........JB.
/ ROPS #2
I would be interested in an answer to this as well...sometimes I just want to unbolt it and leave it in the woods!
/ ROPS #3
does it feel like your in front of a sound cannon? or inside of it? perhaps garbage can over your head?
spray foam, might work i suppose, by giving internal structural support. a high density spray foam (lots of smaller size bubbles) closed cell type i would imagine might work better. guessing a foam for a flotation on of a dock or inside a boats haul? most likely a 2 part mix.
using "great stuff red can", and trying to get a hose or nozzle shoved all the way through the frame and then getting it to fully expand through the ROPS frame as you pull hose/nozzle out... perhaps? though i am guessing you would need to let ROPS frame set bare min a week maybe a 2 to 3 weeks. for the foam to actually cure and harden. if ya tried to start tractor up before then. you may end spinning your wheels. spray foam likes regular air to cure correctly, and when put inside a pipe or like, it takes extra time to cure. i have found that out by trying to fill one of them cheap "float ring" swimming pools ya pickup at pretty much any local store. and reason for 2 part mix style foam. that doesn't really need air to expand and cure.
was going to suggest using some bungie straps. or getting some threaded rod and run just above the hinges (left to right side, and then corner up to middle top). but if ya ever roll the sucker. the ROPS' would most likely pinch at the hings and not work like suppose to, and end up trapping you or harming you.
might be worth a try, some pool noodles. there cheap, take a utilty knife and cut from outside into center. ((kinda like pipe insulation)) and slip them over the ROPS. secure with ductape or plastic zip ties?
old bathroom towels, and some ductape? wrap them around the ROPs frame and secure with some ductape. LOL. *ughs* *shrugs* worth a try?
/ ROPS #4
The 1 part foam actually cures due to moisture not air. The directions actually mention spraying a little water on some surfaces to aid curing.
/ ROPS #5
A 2 part mix would surely quiet things down a lot and cure almost instantly.
/ ROPS #6
Someone has done this in the past and it worked. If I remember correctly!!:laughing:
Hay Feeder (A65640)
Hay Feeder (A65640)
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
KUBOTA M108S TRACTOR (A64277)
KUBOTA M108S...
YALE FORKLIFT (A63291)
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
