ROPS for old 450 case
/ ROPS for old 450 case #1
rpd428
Massey Ferguson 471
I picked this little rascal up for a decent price to do a little work around the newly acquired farm… I’d like to have a ROPS… can one be installed on this particular model? Also where do you recommend I look online if anywhere? Thanks.
/ ROPS for old 450 case #2
You should be able to, but you'll need the mounting brackets, that need to be welded on too. There are salvage yards for construction equipment, just like cars/trucks/ Ag. tractors. I did a Google search for Case Construction salvage yards, and got a ton of hits. https://www.google.com/search?q=cas...AgAGSAYgB0haSAQQyNy40mAEAoAEB&sclient=gws-wiz Not knowing your location, tough to select one near you, you'll have to look. Might be best to check with your local Case Construction dealer, and see if they know of any inyour area.
If you do get one, get the full canopy, including brush sweeps from the top of the front radiator cowling, up to the operators station. It doesn't take much of a tree to snap off an exhaust pipe, that could destroy the muffler under the hood, or worse, the exhaust manifold.
You should be able to, but you'll need the mounting brackets, that need to be welded on too. There are salvage yards for construction equipment, just like cars/trucks/ Ag. tractors. I did a Google search for Case Construction salvage yards, and got a ton of hits. https://www.google.com/search?q=case+construction+equipment+salvage+yards&sxsrf=AOaemvIR3x6kzMQPwPFv86OMPhqZ8vRwyg:1636112392112&source=hp&ei=CBiFYbzVA4fdtQbV95H4BA&iflsig=ALs-wAMAAAAAYYUmGF3pqaO9Gc1mJdAgzO_evCTTHspj&oq=Case+Construction+salvage+yards&gs_lcp=Cgdnd3Mtd2l6EAEYATIJCAAQyQMQFhAeMgYIABAWEB4yBggAEBYQHjoECCMQJzoICAAQgAQQsQM6CAguELEDEIMBOgUIABCABDoOCC4QgAQQsQMQxwEQ0QM6DgguEIAEELEDEMcBEKMCOgUILhCABDoLCC4QgAQQsQMQgwE6CwguEIAEEMcBENEDOgsILhCxAxDHARCjAjoLCC4QgAQQxwEQrwE6CAguEIAEELEDOg4ILhCxAxDHARDRAxDJAzoFCAAQkgM6BQgAELEDOggIABCxAxCDAToLCAAQgAQQsQMQgwE6CAgAEIAEEMkDOg4ILhCABBDHARCvARCTAlAAWKFOYKd3aABwAHgAgAGSAYgB0haSAQQyNy40mAEAoAEB&sclient=gws-wiz Not knowing your location, tough to select one near you, you'll have to look. Might be best to check with your local Case Construction dealer, and see if they know of any inyour area.
Good deal! I’m in Kentucky
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2019 Ford F-250 Crew Cab Pickup Truck (A64556)
2019 Ford F-250...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A67147)
2001 FREIGHTLINER...
Set of 4 Forerunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Set of 4...
2021 Ford Explorer SUV (A64557)
2021 Ford Explorer...
2007 Peterbilt 379 T/A Kill Truck (A64194)
2007 Peterbilt 379...
