ROPS Engineering
/ ROPS Engineering #11
<font color="red">"Based on my personal experience with lawyers, sharks and leeches, " </font>
Interesting grouping, Bob.... /forums/images/graemlins/grin.gif
/ ROPS Engineering #12
Hey, I like my lawyer, I just feel sorry for the sharks and leeches having to be lumped in with the lawyers.
/ ROPS Engineering #13
</font><font color="blue" class="small">( When I load the 8N (with the brush hog on the back) up the ramps onto my trailer, the front wheels are off the ground. I know it will probably never happen, but when I'm on two wheels, I'm terrified that the tractor is going to flip backwards.
It's a terrible feeling in your stomach when this happens )</font>
Congrats on the N.. I'm a fellow N owner as well ( 8n, 2n, NAA ).
I soppose you have a real heavy 5' rotary cutter. I know my 8n will tote my 5' KK and load onmy flatbed ramps without the front end bouncing. I also have a bumpe ron mine.. and imagine it weights a good? 60-75 pounds. I guess if you had a heavy JD, NH, or BH squealer brand cutter.. you might come close to 1.5 or 2x the weight of my KK or a howse rotary cutter. If you don't have a bumper.. run to tractor supply.. they are? 75$ and bolt to the font axle.. And then you can hang suitcase weights off of it ( if you can afford them. ) or even take weight plates from a weight lifting set and bolt them right on to the bumper with a long carriage bolt and some big washers..
I know what you mean about the sinking feeling in your stomach when the tractor is being weird on a slope or a hill.
I once drove my NAA nearly off the front of my flatbed trailer.. and had to do quite a bit of finagling (with help from a couple gentlymen and a jack and timbers ).. and even then.. it was a 'oh-my-gosh' feeling till it was all said and done..
One good thing.. with a mower back there.. as long as you use a rigid toplink ( and not chain ).. you should be fairly safe frome a backflip due to the 3pt connection... still be safe!
Soundguy
TANK MANIFOLD (A55745)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Patterson water pump (A59230)
Patterson water...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
2012 ALTERFER  CAT GENERATOR (A60736)
2012 ALTERFER CAT...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
