Grapple Root grapple - build or buy??
/ Root grapple - build or buy?? #1
shaley
Platinum Member
Tidewater VA.
Ford '92 2120
After looking at other post on root grapples and all the things you can do with these I think I need one. I'll be clearing brush and small trees from a mostly sandy lot. Clean-up is important so it has to be loaded into a truck. My regular bucket is going to make for too many trips.
The 66" Millonzi looks like it cost $1800 delivered and the 60" Markham is $1600. I'm looking a building a 60" single clamp cylinder version.
I will also need a 3rd function valve such as the WR Long or the Surplus Center Item 9-6136 for $109 + D03 base for $47.
Has anyone ever built one and saved any money?
Do you have any comments on material thickness or things you would do differently.
/ Root grapple - build or buy?? #2
I built a 60" 11 tine bucket(30" tines) using angle and thick wall box tube for the tines. It is lighter duty but has held up well for a year now. I am working on a grapple for it now. Depending on the valve used on your woods FEL, it might also be cost effective to replace the 2 spool loader valve with a 3 spool as it simplifies the plumbing quite a bit and there is no wiring as in the electric selector valves. It also makes operation easy/ergonomic. In my case, this is the best option.
If I had to do it over again, I would spend a bit more money(my bucket cost me less than $200 for materials). I would go with flame or plas cut ribs re-enforced with gussets for the tines, instead of box tube with gussets as it would make it a bit easier to rake under brush and debris. The box tube I used(2.5") for the tines, although cut at an angle at the front, still tend to act like a bucket edge if I scrape into sod trying to get under some debris. It lifts the sod and earth like a bucket instead of slicing thru the lighter material. Since I oriented the tubes with a flat side top-bottom, these tend to hold material that should fall thru. I believe I left about 3.75 inches between tines and it probably could have been a bit wider.
/ Root grapple - build or buy?? #3
I think one thing rarely discussed in the "Make or Buy" decision is resale value. A professionally made and designed product, properly maintained and keep out of the weather, is going to be worth a fair percent of what you paid for it after you are done with it. I've never seen anything home made that I could justify spending much on. If what you need is not available commercially, then that's a different situation.
John
/ Root grapple - build or buy?? #4
I agree with JMC regarding value of the commercial product, that said, I wouldn't buy new.
I bought mine off Ebay in great condition for just 700 dollars (that was 1/3 the cost of new) and it has dual grapples for handling odd objects, a plus for my needs.
After pricing the costs to build a proper grapple myself - weighed against the proven commercial product purchased used off Ebay - I couldn't justify the project cost or time investement. I found several grapples in the area of my southern home, bid, won and picked it up on the way to NC.
Of course your situation may dictate other actions. either way, enjoy the grapple, they are a great tool.
Thanks for the replies guys. I see Ebay has a bunch. For $700 I would definitely buy not build.
Gumby; Could you tell me how tall the tines are. I'm talking about the height of the plate blade just before it turns into the tip.
/ Root grapple - build or buy?? #6
The resale argument is nice, but if you buy a new unit for $1800 and sell it for $700 down the road then you are out $1100, but if you build one for $600 then at worst you will be out $600, so the real issue is less about cost as your personal fabricating skills and spare time VS spare money situation :)
/ Root grapple - build or buy?? #7
I'm at the point in my life where "resale value" on attachments is something I'll let my kids worry about after they use it to bury my old carcass. Sorry if that's a bit too morbid for anyone, but it's a reality for me.
/ Root grapple - build or buy?? #8
Well, yes I have. There was a time or two during the process, I wished I had just paid the price. After getting it done, I am glad I did it. I had most of the materials, so we only spent about 300.00 on it. We already had the hydraulic lines for other implements.
This is a link to a thread on it.
I can assure you I am not concerned about the resale value because I don't expect it to ever be for sale as long as I have any say so.
Thanks Neil, That's what I'm talkin about!!
I looked at my FEL valve and it is aleady setup for power beyond so I'm ok there. I'm starting to lay some tine geometry out in CAD. Couple of shops close by have a laser burner and a CNC torch burner. The scrap yards are full of HY80 plate, still lookin for AR400.
/ Root grapple - build or buy?? #10
I have a CNC plasma table 5x10. I am thinking of cutting out kits with everything you need, is right there all you have to do is weld it. What is your opinion? The cost for a 60 inch would be about 500 plus shipping.
/ Root grapple - build or buy?? #11
I have posted this before, I picked up a tomahawk 66" single lid for $650 ish at a Richey Brothers auction. I have been very happy with it so far. I would think that by the time you buy a cylinder, hoses & fittings, and all the steel you would be around $500. You still have to cut, weld, and assemble it, so how much is your time worth? I am all for building attachments if it's cost effective.
/ Root grapple - build or buy?? #12
Everything Attachments played with this idea several years ago. There's a long thread documenting a kit build they gave to one member and he built it. It came out well but I don't think EA ever commercialized selling kits.
/ Root grapple - build or buy?? #13
I for one am coming into retirement age.How much is my time worth ? Well working in my shop with the radio on,building something then having the wife yell out lunch is on is very appealing to me.I will more or less be on a fixed income with no more job overtime to buy toys.But if I could build "stuff" reasonable even if it takes time is still a savings.I would much rather be out puttering on my property than laying on the couch in a development watching the boob tube.Just my .02.
Well it's been 10 years since I started this thread. My wife says I'm a procrastinator. She said that 10 years ago and it's the same wife now. I still don't have a grapple and I still haven't cleared the sand lot I needed the grapple for. I did start a business which takes up all my spare time but man time flies.
/ Root grapple - build or buy?? #15
Hey, it takes time to make a decision on a grapple. Ease up on yourself..
/ Root grapple - build or buy?? #16
Bwahahahaha! It's been almost 10 years since I've been wanting a grapple... I just ordered the hoses to run from my rear remotes to my FEL for it.. Once I get that installed, I'll be looking at ordering the grapple.. I wonder how long it's going to be for me to actually order the grapple?
2018 Ford Escape 4WD SUV (A59231)
2018 Ford Escape...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
MASSAGE CHAIR (A58214)
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
UNUSED IRANCH 39" HYD MINI DOZER BLADE (A60432)
UNUSED IRANCH 39"...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
