Roofing question
/ Roofing question #21
DAVE.......
A suggestion BEFORE you put down the underlayment. Get the peel & stick and put it down before you shingle. Comes in 3' widths just like felt and rols on like a dream. Even Katrina couldn't pull this stuff up!!! You will NEVER be unhappy that you chose that over regular felt. Particularly if you are using OSB for your decking. It provides a self sealing attribute for the nails. I use it on EVERY single job of mine that invloves roof or deck replacement and needs a GOOD moisture barrier.
/ Roofing question
</font><font color="blue" class="small">( DAVE.......
A suggestion BEFORE you put down the underlayment. Get the peel & stick and put it down before you shingle. Comes in 3' widths just like felt and rols on like a dream. Even Katrina couldn't pull this stuff up!!! You will NEVER be unhappy that you chose that over regular felt. Particularly if you are using OSB for your decking. It provides a self sealing attribute for the nails. I use it on EVERY single job of mine that invloves roof or deck replacement and needs a GOOD moisture barrier. )</font>
I already have two roll ready to go...... /forums/images/graemlins/grin.gif
Dave
/ Roofing question #24
If you haven't already bought your materials I would suggest doing so ASP. Just think of all the damage to be repaired south of you...
/ Roofing question #25
Dave, where are the pictures? How can I enjoy my leasure if I can't watch you work?
Actually, I've been doing major yard work and didn't take any pictures either.
Cliff
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2015 Caterpillar 304E (A64126)
2015 Caterpillar...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
