Rolled it over tonight.Question?B2650
   / Rolled it over tonight.Question?B2650 #1
FELMOW2320
Rocky Face,Ga.
Kubota B2650
I loosend the top of the the injector line.Do i need to take the line completetly off the injector or loosen the injector itself
to bleed it.I've never done this before.Any help would be appreciated.
   / Rolled it over tonight.Question?B2650 #2
You might want to explain what you trying to do here....
just trying to make sure it is not hydrolocked before starting.
   / Rolled it over tonight.Question?B2650 #4
Does that model have glow plugs?
Easiest might be removing the glow plugs before turning the engine over IMO.
Loosening the injector line off the injector is not to prevent hydro locking.
How do the glow plugs come out on this model.Do they just unscew after taking off the the flat piece that connects them.
   / Rolled it over tonight.Question?B2650 #6
undoing a injection line will do nothing for you, either pull the injectors or the glow plugs out, also check your fluid levels, and check for spilled acid from the battery etc
   / Rolled it over tonight.Question?B2650 #7
Yeah, just pull the glow plugs. They should be threaded in.
Fluid levels are good.Tractor was on it's side for about 10 minutes before I could get it turned back over.I would have took pictures but was in a hurry to get turned back over and didn't have my phone with me.I'm just hoping the engine is not hurt.It kept running till i could shut it off.
   / Rolled it over tonight.Question?B2650 #9
May I ask how you put it on it's side? I'm glad you're not hurt or dead!
I was trying to taper the end of a bank that has been dug out.Got real tippy real quick and tried to back off when it rolled.Not a scratch on me and the only scratch on tractor was on a light mounted on the rops.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
(2) 300 GAL WATER TANKS (A50854)
(2) 300 GAL WATER...
International 133 6 Row Cultivator (A50514)
International 133...
John Deere D110 42in Riding Mower (A49461)
John Deere D110...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A49461)
2000 Trail King...
