road register
/ road register #1
tezzer
yorkshire
ford 1720
hi all i have just bought a ford new Holland 1720 compact tractor. my first impressions are not very good i am hoping to drive it on the road. but don't know if its me or the gears but i am not looking forward to it. i have loads of things to ask but one thing at a time. the person i bought it off has had for the last ten years it does not have a number plate or log book. in the past it looks as thought it has has a tax disc in the window. i have been told that to contact friends of Ferguson as they are recognized by the dvla and let them do the paper work for me can i have your thoughts and opinions please thank terry :confused2:
/ road register #2
Welcome to TBN.:tractor:
/ road register #3
When you say "hoping to drive it on the road" how fast do you plan to go. I have had my 1720 for approx 15 years and it has done everything asked of it. Great little engine.
/ road register #4
tezzer,
I do not think any American or Canadian here can answer your question. We do not have to license(tax disc) our tractors for road use.
/ road register
mine is a manual gear box and when i use the range in high the tractor engine starts to die when i try to pull away. also when i change gear say from first to second when i press the clutch in and the tractor just comes to a halt instead of keeping moving. is it supposed to do this thanks for your replies everybody
/ road register #6
I am not sure of the 1720, but my 1300 does not have syncronized gears so you should be stopped , to change gears. If the clutch is working properly you should be able to pull away in all gears unless there is a heavy load attached. When i press the clutch my tractor it will coast a short distance before stopping. Are the brakes adjusted too tight?
/ road register
that what i thought could it be the brakes sticking i will have to check the rear ones tomorrow. I know the front brake are not sticking as i used the loader to lift the front end up and spin the wheels.AS i say i have only had the tractor since Friday and with not having any instructions on what does what it takes some getting used to.
/ road register #8
Operator and service manuals are available on ebay and amazon. com, in the U S ,not sure if their available where you are,but would be very helpful if you can get one.
/ road register #9
I think you're right about the front brakes not sticking, it doesn't have any that I'm aware of.. :)
If you want to travel along the road you should learn to double-clutch when you shift so the gears don't grind. It works like this.. as you're rolling along in say, second gear, you depress the clutch and pull the shift into neutral, then release the clutch completely. Immediately (while you still have momentum) depress the clutch again and engage the next higher gear (third). Continue until you're in high gear. It works better going upward than downshifting in my experience. Before there were synchronized transmissions this is how all gear driven machines were shifted. Good luck.
Sean
/ road register #10
remember.. this machine , if the straight manual like my 1920 was. has gear ranges too. 3 gears and 4 ranges.
shift onthe fly is gonna be a nightmare...
/ road register #11
Sean
Tractor trailers still don't have synchronized transmissions, and this is the way it is done. Although, with a truck.........and the speed available.......it can be done without the use of the clutch at all. And with practice, downshifting can be done without using the clutch also............even when shifting from high to low range.
Upshifting for me, was a breeze.............downshifting took a while to catch onto.
/ road register #12
In New Hampshire we have to register our tractors to drive them on the road. SMV's are not an expectable option per state law. I registered mine, because if I travel around town occasionally, and the risk is not worth it for me. Especially if I was ever to have an accident. An unregistered vehicle can show fault, even if you are not at fault.
I would check with your local Constabulary and see how their enforcement is of farm machinery operated on public rights of way. You can also contact your local DVLA. This may be helpful: https://www.gov.uk/register-farm-vehicle
Congratulations on the new tractor!
tezzer,
/ road register #13
Tezzer, You need help from somebody local. Try the Farmer's Weekly website Farming & Agriculture News from Farmers Weekly Interactive. Register and use the forum. There are some very knowledgeable people on the site with experience of UK models of tractors. As Wolftree advised you yesterday US and Canadian people (the vast majority on this forum) cannot answer your questions.
I cannot remember the rules regarding limited road use. Check out the DVLA website, and if no luck there either contact them, or again ask on fwi - but remember you might not have the full legal answer from another farmer.
/ road register
thanks for the advice Soundguy today i jacked the back of the tractor off the ground, then tried to turn each wheel by hand i could not budge them. so i had a look at the rear wheels for the brakes. you guessed nothing there so i traced the hand brake cable and found that it was attached to a plate on or near the axle so i disconnected the foot pedal linkage on both sides. then gave the metal plates or whatever you call them a clout with the hammer on both sides of the tractor and instantly i could move both wheels. so another problem solved
/ road register #15
I wish that we didn't have to, because a SMV is so much easier. The plate is only $12 so I can't complain too much..
tezzer,
/ road register #16
Terry,
What type of work are you going to be doing on your new tractor?
/ road register
this is the tractor on eBay 271215018722 copy and paste you will see the flail mower it came with. i have done some paddock grass cutting today with it. but after looking underneath i found that a few of the flails are missing. I am hoping to get a few jobs cutting grass. also over here we have what we call allotments where people rent small plots of land from the local council and i am hoping to get a plough and rotovator to earn a bit of money doing the allotments. this also raises another question, at the moment the tractor has got turf tires on i was hoping to get a full set of agg wheels but i have been told that i will need bigger rims that what are already on the tractor the rear ones are 13.6.16 on 12 inch rims
/ road register #18
You may not need to change the tires and wheels. I can pull a plow(plough), and a tiller(rotovator) will work just fine with turf tires. I have both implements.
I can also pull a middlebuster(potato plow) at full depth with my turf tires.
/ road register #19
Great looking tractor! I have the same size rims on the front of my Iseki, and close on the rear with Ag tyres. You should be able to find some no problem for your rims, and most likely on eBay. You could certainly try without the Ag tyres first once you get the rotovator, and plough, and see how it does. Thats great that you have a cab too! What type of food are you going to try growing on the plot? You could try these guyshttp://www.allterraintyres.co.uk/index.p13.6.16hp?main_page=index&cPath=1464&zenid=57bc055383c37cb2f921297ae183a076
/ road register
i once has a kubota st30 hydro on turf tires and we get very wet winters here and i used to struggle to use a plough with it. i am growing spuds cabbage lettuce turnips collies broccoli peas beans tomatoes ect thanks for the tire link NHmitch you find stuff over here better than i can ps just got it fully insured i dont know what it is in dollars but £80 for year dose not seem to costly
2016 Ford F-150 Extended Cab Pickup Truck (A64557)
2016 Ford F-150...
JOHN DEERE 544K (A67714)
JOHN DEERE 544K...
2015 GMC SIERRA 3500HD (A67714)
2015 GMC SIERRA...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
PALLET OF CUT-OFF VALVES (A68842)
PALLET OF CUT-OFF...
