Rk37 shuttle shift it wont move
/ Rk37 shuttle shift it wont move #1
Nimben@200873
Rk37sc 4x4 shuttle shift
Got rk 37 sc shuttle shift won't move in 2 wheel drive no noise bang or nothing I put it in 4 wheel drive and front wheels will pull
/ Rk37 shuttle shift it wont move #2
Got RK37sc shuttle shift won't move in 2 wheel drive no noise bang or nothing I put it in 4 wheel drive and front wheels will pull
Does the RK37sc have a cleanable hydraulic filter or spin-in? Chances are, it needs to be cleaned and reused or a new spin-on filter. When using a spin-on always go for the TALLEST possible that will fit. Too small means, you will be changing it more often. Taller means, more surface filtering and op-tune flow for the suction pump.
/ Rk37 shuttle shift it wont move #3
Have you tried to move in 2WD but engaging the diff lock? This should tell us if the problem is in the diff or in one of the rear final drives.
/ Rk37 shuttle shift it wont move #4
I agree with ptsg to perform a test by engaging diff lock. Sounds as if tractor has a problem in the differential or a broken rear axle. Have you checked to be sure rear tire isn't slipping on the rim?
Cub Cadet MOWER (A64557)
Cub Cadet MOWER...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
2024 Better Built 7'x12' Trailer (A64127)
2024 Better Built...
2011 Chevrolet Silverado Pickup Truck (A62613)
2011 Chevrolet...
Fertilizer Openers (A65640)
Fertilizer Openers...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
