Tires RK 24 tire pressures
/ RK 24 tire pressures #1
JLH4
Hobby Farm in Central Kentucky
Rural King - RK24
:confused:Where can I find the tire pressures for R4 tires on the RK24. All the operators manual has is the tire size.:(
/ RK 24 tire pressures #2
Look on the tire sidewall -- if you have a front loader and/or carry implements you can run the max pressure quoted on the sidewall. That is standard practice across most types of construction equipment and tractors. Some people will dial back a few PSI in specific scenarios. If you have to ask why and how much, then you are probably not one of those people. ;)
/ RK 24 tire pressures #3
My RK24 with R4 tires have the following Max PSI on the tires:
Front 10
Rear 25
That's about where I leave them for good all around use. But, I do normally have the FEL and backhoe on my tractor, so the tires are ready for max weights front and rear. Your usage may vary from mine.
/ RK 24 tire pressures #4
Ohio, Can you double check.....I looked at my tires and the front are 40 and the rear 25. I know looking in he manual, it has no information at all.
Thanks
mike
/ RK 24 tire pressures #5
Definitely will. 10 pounds does seem low. Maybe I didn't wipe all the mud off when I read it?
/ RK 24 tire pressures #6
Cowboy, Let me know, If I can make it out to the garage this week, I will put my reading glasses on and double check......Thanks again,
/ RK 24 tire pressures #7
Can't imagine you would be able to turn it with a bucket full and 10 lbs in the front. The tires would probably roll right off the rims.
/ RK 24 tire pressures #8
coastie, you are absolutely right. 40 front and 25 rear. :tractor:
/ RK 24 tire pressures #9
Cowboy, thanks for double checking, I was not looking to going out in the cold to double check....Which part of Ohio are you in?.....I am 15 mile or so East of Cleveland.
mike
/ RK 24 tire pressures #10
I know...15-20 degrees here too. I'm down south of Medina-close to 71 & 76 intersection.
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
2018 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2018 KOMATSU...
16' 5" METAL STORAGE RACK (A60432)
16' 5" METAL...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
(14) WOOD PALLETS (A60432)
(14) WOOD PALLETS...
