Tires RK 24 tire pressures
/ RK 24 tire pressures #1
JLH4
Hobby Farm in Central Kentucky
Rural King - RK24
:confused:Where can I find the tire pressures for R4 tires on the RK24. All the operators manual has is the tire size.:(
/ RK 24 tire pressures #2
Look on the tire sidewall -- if you have a front loader and/or carry implements you can run the max pressure quoted on the sidewall. That is standard practice across most types of construction equipment and tractors. Some people will dial back a few PSI in specific scenarios. If you have to ask why and how much, then you are probably not one of those people. ;)
/ RK 24 tire pressures #3
My RK24 with R4 tires have the following Max PSI on the tires:
Front 10
Rear 25
That's about where I leave them for good all around use. But, I do normally have the FEL and backhoe on my tractor, so the tires are ready for max weights front and rear. Your usage may vary from mine.
/ RK 24 tire pressures #4
Ohio, Can you double check.....I looked at my tires and the front are 40 and the rear 25. I know looking in he manual, it has no information at all.
Thanks
mike
/ RK 24 tire pressures #5
Definitely will. 10 pounds does seem low. Maybe I didn't wipe all the mud off when I read it?
/ RK 24 tire pressures #6
Cowboy, Let me know, If I can make it out to the garage this week, I will put my reading glasses on and double check......Thanks again,
/ RK 24 tire pressures #7
Can't imagine you would be able to turn it with a bucket full and 10 lbs in the front. The tires would probably roll right off the rims.
/ RK 24 tire pressures #8
coastie, you are absolutely right. 40 front and 25 rear. :tractor:
/ RK 24 tire pressures #9
Cowboy, thanks for double checking, I was not looking to going out in the cold to double check....Which part of Ohio are you in?.....I am 15 mile or so East of Cleveland.
mike
/ RK 24 tire pressures #10
I know...15-20 degrees here too. I'm down south of Medina-close to 71 & 76 intersection.
17307 (A55853)
17307 (A55853)
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2016 Ford Explorer 4WD XLT SUV (A59231)
2016 Ford Explorer...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
30in. Pallet Forks and Frame Skid Steer Attachment (A59228)
30in. Pallet Forks...
