reverse disc removal
/ reverse disc removal #1
sergeant69
south texas
troy bilt horse and pony
in the manual for my 71 horse 1 it says to remove the bolt and washer and the reverse disc comes for replacement of disc or belts. really? my reverse disc looks like its welded/rusted to the pulleys. no bolts etc to remove. suggestions?
hello?? anyone out there? surely someone has had this same problem?
/ reverse disc removal #3
I have never had to replace my reverse disc, but mine is from the early 80s, I think. So it might be different. Do you have 1 belt or 2? Can you send a picture? Mine is on a remote property 3 hours away, so I can't look at it.
actually, I don't know that it even HAS to be replaced. other than a small nick or two it looks to all be there etc. but if it needs to be done. nows the time as it and the pulleys are off the motor. I have no problem posting a pic unless it requires that cloud thing or whatever. it has 2 belts/pulleys.
/ reverse disc removal #5
I believe you can look at a parts schematic on their website.
/ reverse disc removal #6
Unless you back up a lot, i don't know that I would worry about it. You don't need to do the cloud thing to post a picture if you can get it on your computer.
2006 Mercury 115ELPTO 115hp Outboard Boat Motor. (A66738)
2006 Mercury...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
70" Padfoot Shell Kit (A68134)
70" Padfoot Shell...
FOREDE WATER MIST CANNON (A67714)
FOREDE WATER MIST...
93b (A65054)
93b (A65054)
John Deere 2840 Tractor (A64047)
John Deere 2840...
