Reuse hydraulic hose?
/ Reuse hydraulic hose? #21
Apparently most of you guys that read my post couldn't understand the last sentence.
For those that put a few dollars in your pocket above safety, go talk someone who has been the victim of oil injected under the skin, or someone who has has been injured in some other manner due to a hydraulic failure.
Nobody here has to accept or agree with my principles, I just don't care that much.
Link To GRAPHIC picture.
/ Reuse hydraulic hose? #22
I was the one that posted that picture on TBN. That accident was caused by a hyd impact gun, and it did not say whether the hose was new or used. They did say that it burst at the crimped fitting.
With all due respects to all concerned, I can almost bet that if you own or work for a hyd shop, that the policy is to fix a customers product if at all possible, or sell him a new setup. I have been around to the shops in my area, and they will fix what the customer brings in with in reason. Most of them were a little vague on warranty though. They definitely did not want to write the warranty on paper.
Each individual that deals in safety has a responsibility to state the facts, and make the other person aware of them.
/ Reuse hydraulic hose? #25
You can have those nasty accidents with bad crimps on new hoses just as easily as bad crimps on old hoses, Poor workmanship and poor judgement can cause "accidents" on just about any item or situation. I have been sprayed with hot hydraulic oil a lot of times, just as many with fairly new hoses as with old hoses. I have had many burst with not a sign of wear on the outside which is what most of mine do on my FEL. Maybe the hose is defective and all of them were made from the same reel but burst hydraulic hoses are a common occurence and injuries like the photos do happen but are a very rare occurence. You have the same type of injury with high pressure washers operating in the ultra high pressure range and they are just as bad. Most of them are not from burst hoses but the operator running the wand across his hand or foot or some other body part.
/ Reuse hydraulic hose? #26
I have been sprayed with hot hydraulic oil a lot of times....
"You are the man Gary....good for you....whats the "record" in one day???"
If I got sprayed once I would go and get a better insurance, plus making sure not getting sprayed again....
Maybe you have to take a look at the safety procedures at work....:confused2:...
/ Reuse hydraulic hose? #27
One can't just justify using "bad" hose, just because accidents can happen with "good" hose too...:confused2:
/ Reuse hydraulic hose? #28
No one is suggesting the use of bad hose. Those of us who reuse hose have been quite clear on that so your point is just rhetorical.
The question is whether to always or almost always use new hose on CUT related hydraulics. If the answer is that you always need new hose "just in case" then that same pricinple might be applied to the entire tractor. Why not replace the entire tractor each time a hose leaks. Never know when the next hose on that used tractor is going to blow, right?
The reuse of good condition hoses is just a practical economic matter and we make similar judgments and beneficial compromises in all areas of life daily. Do you replace a car tire with a simple puncture or repair it?
I don't need a robot programed to say "replace it" when I go to a hydraulic shop. I need an experienced knowledgable mechanic who can help me assess condition and also understand the risks associated with my particular application. The final judgment is mine but I'd like to trust that the mechanic is not just giving me a knee jerk reaction.
/ Reuse hydraulic hose? #29
I'll agree with all that with one exception. If I am making the hose and selling the parts & pieces, the decision to repair or replace AT MY LOCATION is mine, not yours. You can always disagree and go elsewhere.
/ Reuse hydraulic hose? #30
=AKKAMAAN;2276477]
IMO, posting this type of image without a caveat is not in good taste...I am not disturbed by the content but some folks that aren't expecting something like that might just lose their lunch...
I suggest using a link to images not everyone may not want to see with a warning about the content...
/ Reuse hydraulic hose? #31
Sorry pal....didn't know you were at lunch....:thumbsup:
Do not "spin the internet-chamber" while eating...
/ Reuse hydraulic hose? #32
like I said...it does not bother me but it might some...
the images should be removed IMO... it's no different than posting pictures of roadkill etc...
/ Reuse hydraulic hose? #33
I have to agree with guys that reuse, if hoses look good except in situations where some one could be endangered from a flaw, such as some one in a bucket truck. Save the money.
I also agree with guys that have shop that repairs hoses to say take it somewhere else.
I have been waiting for a worn hose to break on my loader for 2 years! Untill then I am going to get the goodies out of it. I have also had new crimps from a shop that failed. So keeping yourself out of danger is a consistant practice.
I learned something new today, didn't know that fittings were designed to mate with specific hoses. I always thought that 1/2" hose was 1/2" hose and a 1/2" fitting fits 1/2" hose. I'm very leery of that 2000 psi trapped inside the hose. I want it to stay there, kinda like the genie in the bottle. As long as it stays trapped, it'll work for you. If it gets out, bad things happen.
Anyway, I have a 1 year old hose (so it's "new" from the manufacturer) I want to tap into to add a diverter circuit for a grapple on my FEL. Hose type is unknown, it's whatever JD uses. My concern was whether the oil would prevent the fitting from grabbing the hose tightly enough. From the posts, it appears I can have a shop cut the hose in half and put fittings on it and expect it to hold as well as a hose without the oil having been run thru it.
/ Reuse hydraulic hose? #35
You cannot just cut into a hose and add a tee. You could add a selector valve in the curl circuit, using a selector valve. With everything connected correctly, the curl will work normally. When you flip the switch on, the fluid is now going to the grapple.
/ Reuse hydraulic hose? #36
I love how these guys that don't deal with hoses and hydraulics for a living know more about them than us that do. Nicely put Rick.
/ Reuse hydraulic hose? #37
Yes. And of course yous know more about the sevice of hoses on our machinery than we do.
larry
/ Reuse hydraulic hose? #38
larry
Why wouldn't they know more about the hydraulic hoses on your machine? You'd expect an equipment mechanic to know more about your machine than you do. I'd expect them to know more about hydraulic hoses than I do, and I am sure I have built and seen more hydraulic hoses than most tractor owners here have.
Brian
/ Reuse hydraulic hose? #39
Brian
I think the point is more that while some shops may be extremely conservative because of liability issues (man lifts etc) those of us who own CUTs know how we use them and can pretty easily understand the consequences of any particular hose springing a leak or breaking. If my BH dipper stick hose breaks or leaks, I know that it is never closer than six feet or so to me under load and that it is covered with a nylon sheath which will diffuse any spray as well as running on the opposite side of the boom. Under those circumstances I might feel perfectly comfortable using an old hose while the hydraulic shop thinks only of worst case, life on the line, scenarios (as noted by a couple of the guys here).
Just like a patient can know their own body better than the local doc, we CUT owners can sometimes make more informed decisions than an expert sitting in a hydraulic shop can without our input. Nobody is claiming that we know more than the hydraulic guys but that doesn't necessarily translate to deferring to their standard policy as the best decision for us. They can refuse of course and I would certainly understand that the liability and insurance issues they deal with might prevent them from ever reusing a hose but in that case I would thank them and take the business elsewhere.
/ Reuse hydraulic hose? #40
Yes. And of course yous know more about the service of hoses on our machinery than we do.
larry
Brian
I wonder if you missed the [now] highlighted word when making your response. The particulars of the hose, its service, and its failure that would justify reasoned choice in renewing the connection. To say that they know more about hose is certainly true, but I dont credit that as an excuse to flip entirely in one direction regardless of the specifics. You can be sure that there is a mixed hose and connector combination out there that actually works better than the one specified. Every mix is not definitively wrong.
larry
2017 Ford F-150 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2021 Ford Explorer SUV (A64557)
2021 Ford Explorer...
KL480 Ventrac tiller
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
