return line
/ return line #1
Gabbertc
John Deere 4105
Good afternoon,
i am looking for information on how to plumb my hydraulics on a John Deere 4105 to allow me to run a front mounted hydraulic brush cutter
Thank you,
/ return line
will just adding a check valve at the hydraulic motor between the supply and return lines to make a continues loop work ?
/ return line #3
O guess the question I have is where are you planning to plumb on the tractor? The remotes?
/ return line #4
Depending on the capacity of the remote system and the need for the mower you can use the remote valves. Be sure you have the fluid running the correct direction, so the mower does not run backwards. My guess is the remote system will not be sufficient to run the mower as desired. Also using the tractor's hyds to run the mower may require a cooler to be installed to prevent overheating the oil.
They do make a self contained hyd oil pump to power such using the pto power of the tractor. I use a pto powered self contained unit for my boom mower. I found old mower and was able to use it only needing new pump and hoses.
Not suggesting this unit as all, but to give you an example of self contained system. Power Pack Hydraulic Power Unit
/ return line #5
whats your on/off control for the mower? Loader valve, rear remote, or ?
/ return line
i have installed an Arlillian 3rd function kit for my grapple, and i have been seeing loader mounted brush cutters and was hoping this is something i could do.
i have an old pto brush cutter im wanting to convert if possible.
thank you all for you replies
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
TANK MANIFOLD (A58216)
2019 CATERPILLAR 259D SKID STEER (A64279)
2019 CATERPILLAR...
Bell 1600 Gallon Nurse Trailer (A63688)
Bell 1600 Gallon...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
