Replacing Wheels/Tires
/ Replacing Wheels/Tires #1
Licklog
East Tennessee, GSMNP, Sevierville, Pigeon Forge,
CC 7205
I have a cc7205 that needs new front tires. They currently have Ag tires all the way around and I intend to replace the worn front with turf since I do very little tractor work in the field. It is mostly on pavement or gravel.
I need to remove the wheels and take to the COOP so they can install the replacements. I can lift the tractor with the bucket to access the wheels but I can find no information on where to support the front end with jack stands or even where to jack it up if I didn't have a bucket. I have the owners manual and a set of service manuals from the previous owner.
Any info would be appreciated.
TIA
Licklog
/ Replacing Wheels/Tires #2
Can't you put the jack stands on each side of the axle?
/ Replacing Wheels/Tires #4
Is this your tractor? or similar?
Once you lift the tractor I'm sure you can prop up both transfer cases and be safe/solid. Almost positive the front axle pivots up/down so it's more safe to jack stand or block up both sides of the axle.
If you still in doubt take a pic of the front and someone here will paint in the proper place to brace up.
/ Replacing Wheels/Tires #5
In my copy of the 7000 service manual it shows the axle being supported on a jack stand right at the end of the housing.
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
2021 John Deere 4044M (A64126)
2021 John Deere...
Pallet of 3 Large Electric Motors (A62679)
Pallet of 3 Large...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
