Replacing Wheels/Tires
/ Replacing Wheels/Tires #1
Licklog
East Tennessee, GSMNP, Sevierville, Pigeon Forge,
CC 7205
I have a cc7205 that needs new front tires. They currently have Ag tires all the way around and I intend to replace the worn front with turf since I do very little tractor work in the field. It is mostly on pavement or gravel.
I need to remove the wheels and take to the COOP so they can install the replacements. I can lift the tractor with the bucket to access the wheels but I can find no information on where to support the front end with jack stands or even where to jack it up if I didn't have a bucket. I have the owners manual and a set of service manuals from the previous owner.
Any info would be appreciated.
TIA
Licklog
/ Replacing Wheels/Tires #2
Can't you put the jack stands on each side of the axle?
/ Replacing Wheels/Tires #4
Is this your tractor? or similar?
Once you lift the tractor I'm sure you can prop up both transfer cases and be safe/solid. Almost positive the front axle pivots up/down so it's more safe to jack stand or block up both sides of the axle.
If you still in doubt take a pic of the front and someone here will paint in the proper place to brace up.
/ Replacing Wheels/Tires #5
In my copy of the 7000 service manual it shows the axle being supported on a jack stand right at the end of the housing.
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
2010 KEYSTONE LAREDO (A65643)
2010 KEYSTONE...
2021 Felling 29FT FT-45-2LP Trailer (A64194)
2021 Felling 29FT...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
