Loader replacing hydraulic lines - how to bleed?
   / replacing hydraulic lines - how to bleed? #11
I think I could disagree on this. I tried this today and it didn't work. Can you personally contact me, see if you can help me over the phone? I have a JD 790 front loader bucket.
Glenn this post is from several years ago. 2012 and 2014.
A new post in the hydraulics section with a bit more of a description of your problem may get more responses.
Good luck
   / replacing hydraulic lines - how to bleed? #12
When raising/lowering the loader or dumping/curling hold the control lever for a few extra seconds at each end of the stroke to force the air out until you hear the valve go over relief. You will only need to do it 2 or 3 times to bleed the lines.
   / replacing hydraulic lines - how to bleed? #13
For sure hydraulic lines should self purge by simply working the levers to raise lower etc. IF it isn't working, you have another problem besides air in the lines.
   / replacing hydraulic lines - how to bleed? #14
I have and IH 244 with a loader. The loader works but is slow. Some of the lines do leak but before i replace them i want to make sure nothing major is broken. How to i check the hydraulic fluid level in my tractor as well? Does anyone know where i can buy a hydraulic filter for my tractor? I'm knew to diesels and hydraulics, so any advice would be greatly appreciated.
Ben
I dont know it those older tractors had filters on the hydraulic or if they only had a strainer. If it is slow to operate, the first thing I would check it to see it the filters/screens are stopped up. Slow to operate is not a symptom of air in the line as much as lack of flow in the system.
   / replacing hydraulic lines - how to bleed? #15
Actually I was wrong, it was my comprehension line that popped out. All I did was put it back in and it worked like new.
Case 870 Agri King Loader Tractor (A59814)
Case 870 Agri King...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
40' CONTAINER (A52706)
