Replacement rims
/ Replacement rims #1
LyleB
Central Texas
None (yet)
Just purchased a Craftsman garden tractor - 25hp Kohler, 54" deck. It has 23x10.50x12 rear tires. These of course are turf tires, but I'd like to get some ag type tires to use with ground engaging equipment later. I really don't want to have to change tires all the time, so wanted an extra set of rims to mount the tires on. Figured it would be a lot easier just to swap each time. Sears wants $95 apiece for them and frankly, that just ain't going to happen! Surely someone out there sells these rims cheaper than that. My search so far hasn't turned anything up, but I may be looking in the wrong place. Any suggestions? Thanks.
/ Replacement rims #2
It is myunderstanding that MTD makes most of the Craftsman running gear. They might be able to provide a better price on the rims. I would contact them at www.mtdproducts.com and send them an email, providing whatever Sears part number you have. You might also take a tire and rim to a local lawnmower repair shop to find out if they have a matching used set that would work. They could probably order the tires you want, also.
/ Replacement rims #3
AYP also makes alot of Craftsman tractors. What is the model number of the tractor or better yet the part number of the rims & I will do a little searching?
/ Replacement rims
Sears model no. is 917.276090, Part no. is 106277X624. This particular garden tractor was built by Electrolux (Poulan folks). Thanks.
/ Replacement rims #5
Lyle:
if you update you're profile so we would know where you are fron people in you're area could point you to a good place, here in my area stuff like that is on the shielf at Glenns Surpluss in Shelby Ohio. 1800 634 6470 I DON'T know if they SHIP or not?
mark M /forums/images/graemlins/blush.gif
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
Case 580 Super E Backhoe Loader (A66285)
Case 580 Super E...
Rhino 7.5ft Rotary Mower (A64127)
Rhino 7.5ft Rotary...
2023 Bobcat Mini Grapple (A64126)
2023 Bobcat Mini...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
