Replacement RC PTO shaft
/ Replacement RC PTO shaft #1
croasdale
White Stone, VA
John Deere 955
I need to replace the shaft on my bush hog. Here's what I have...
A 1-3/8" splined shaft on the tractor PTO.
A 1-3/8" splined shaft on the hog.
I am thinking of replacing the old broken shaft with a new one at TSC. (#271318)
I have two questions...
Can I put a smooth bore yoke on the RC splined shaft and run a shear pin through them? I know it's not optimal, but I can't run a shaft with splined yokes at both ends unless I put a slip clutch in there which would then create new problems with shaft length and other issues.
What do the series numbers mean? TSC has shafts in series 14, 28, 35, etc.
Thanks
/ Replacement RC PTO shaft #2
croasdale said:
I need to replace the shaft on my bush hog. Here's what I I know it's not optimal, but I can't run a shaft with splined yokes at both ends unless I put a slip clutch in there which would then create new problems with shaft length and other issues.
I personally wouldn't mate splined with round. Too much potential for slop > slop eggs out bolt holes > egged-out bolt holes ruin equipment.
PTO shafts are considered "cut-to-fit". You can't go wrong with a slip-clutch protected RC. Matter of fact, your new PTO shaft may even come with instructions to do just that (cut to fit). If not, there are plenty of us who've already been where you're at now
//greg//
/ Replacement RC PTO shaft #3
What series of mower do you have, I might point you right direction, TSC probably will not have your correct one in stock (unlikely).
I can get one
One of the problems I'm having is the cutter is an old model my dad owned that has been completely repainted with no identifying marks left on it. All I can do is try to match up a shaft by measuring.
I'd like to buy locally since I can return stuff more easily if I have to but I may have to order one. The medium duty with clutch (CS53516) from CCMachinery may be just the ticket.
Thanks.
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
generator trailer (A61569)
generator trailer...
2004 Chevrolet Silverado 1500 4x4 Pickup Truck (A61573)
2004 Chevrolet...
2002 International 9200i Truck (A61307)
2002 International...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2008 Unverferth 220 Rolling Harrow (A63116)
2008 Unverferth...
