Replacement lights
   / Replacement lights #1
hardhat
One of the work lights on the back of my 5610 burned out. Replacement is $27 for the entire light assembly. All I need is a new bulb. Anyone know where to get these?
   / Replacement lights #2
If you can get the light open and bulb out, take it to an auto parts store and ask. It's usually a good idea NOT to touch the new bulb with your bare fingers because the oil will cause the bulb to burn out.
I can get the bulb out but it looks like it is soldered to the part that screws to the light housing.
   / Replacement lights #4
Never saw one like that - is there a number on the bulb base ? You might want to take the whole housing (with bulb) in to your dealer and ask. :confused:
Dealer found bulbs. Was the bulb and the part that screws into the housing. $12/ each. Will try to find way to replace just bulb and re use the screw in part, will just take a little soldering I think
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
80in HD Tooth Bucket with Side Cutters (A51039)
80in HD Tooth...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
