Replacement drawbar for JD 1070
/ Replacement drawbar for JD 1070 #1
gregfender
Marion, NC
Kubota L2501 HST
I need a swinging drawbar for a JD 1070. Any idea where to get one besides the JD parts store? I want to avoid paying $170 for one!
/ Replacement drawbar for JD 1070 #2
Its just a generic steel bar with 2 holes, one on each end. Buy stock and drill some holes.
/ Replacement drawbar for JD 1070 #3
TSC has them in stock, not sure about $ but I'll bet a lot less then $170.00.
DevilDog
/ Replacement drawbar for JD 1070 #4
I just bought the standard one from TSC for my Deere 855. The drawbar was $40 and I had to drill two holes. But other than that it was a perfect fit.
Greg
/ Replacement drawbar for JD 1070 #5
Are you sure you want a "swinging draw bar"? Or just a regular straight one? Two different things...
/ Replacement drawbar for JD 1070 #6
Greg
I was looking at one of those for my 955. Just curious, but what were the holes you drilled needed for?
/ Replacement drawbar for JD 1070 #7
If there are other older tractors that use that same draw bar, you may find it in some of the JD bone yards. I found one in PA for a 301A, and got the draw bar and all the other parts I needed to put it on for less than the price of the draw bar from JD. Have you tried Agrisupply in your area? Newer tractors like that can be impossible to find parts other than dealers or bone yards. A&I, one of the best for tractor parts like that does not do compacts like yours, or compacts at all.
Using a piece of stock and drilliing the holes is not a good idea, as draw bars are very hardened high quality steel. Regular mild steel will bend like made.
/ Replacement drawbar for JD 1070 #8
I was at Orshceln's (local farm & home center) on Saturday and they had a universal drawbar that looks just like the one at TSC. It was only $32 so I picked it up. Fit like a glove on my 955, but like gsdavis, I had to drill a 3/4" hole for the shear pin.
/ Replacement drawbar for JD 1070 #9
It needed two mounting holes drilled. Actually just one will do if you don't plan on moving it. The factory one is just about identical to the TSC one. You can see the specs of the factory drawbar on JDParts.
The drilled hole is for the mounting pin which is more rearward that the any hole on the TSC one.
I hope that makes sense.
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2015 HYUNDAI HX220L EXCAVATOR (A64279)
2015 HYUNDAI...
JOHN DEERE 8330 TRACTOR (A63291)
JOHN DEERE 8330...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A64194)
John Deere 12in...
9 SHANK CHISEL PLOW (A63291)
9 SHANK CHISEL...
