replaced jet pump.
/ replaced jet pump. #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
one of the lines going to the jet pump sprung a leak at my sisters last week: after having one plumber there for @ 3 hours, and him saying it was fixed: which it wasn't...she couldn't get any water at all in the house: and then having another plumber there for 4 hours, and getting the leak problem fixed, only to end up with another problem: the pump wouldn't shut off: i went to lowes and bought a 110volt submersible pump, pipe and wire and replaced the whole thing in less than 4 hours. when you work on a jet pump thats been in for 30 years, like this one had, you tend to shake lose rust and crud, which clogs the "jet" and the pump will run, but not build up pressure an kick off. anyway, i cannot understand why anyone would put in a jet pump, when the others are about the same price and work so much better? plus use about a third the electricity to get the same amount of water?
heehaw
/ replaced jet pump. #2
because that submersible pump will last a year maybee 2 on an "continual" usage a well pump is under.
a new shallow well jet pump is only about $200. a deep well jet pump is a fuz more.
the submersible here at the house has been in for about 24 years, and never had a single minute of down time: a friend helped me drop the pump in yesterday: he was telling me, he put a 3/4 hp pump in over 12 years ago, and it has supplied 3 houses and a commercial garage for all that time and its never been looked at again, since the day he installed it. the pump i put in was from lowes, and it cost $304: theres a couple local hardware stores that put them on sale pretty often for a lot less than that: but of course, when you need it, you need it immediately..
heehaw
/ replaced jet pump. #4
Depends on the depth of the well and I thought that the foot valve for a shallow well pump housed both lines inside the foot valve. So crud I believe is coming from metal pipes?
Today the plastic lines are so much more useful in water lines than the old metal ones were.
with the jet pump, 2 lines went down the well: one is 1 inch, the other, 1.25 inch: they hook onto a fairly big metal housing that has the "jet" inside, and the foot valve is on the bottom of the housing. the lines where plastic, the rust and crud was coming from inside of the jet housing, the pump and the expansion tank. luckily, the well was only 36 ft deep in my case, putting the
submersible pump in was just so easy: no worrying about having water to prime the pump etc etc: turn on the electricity and you have water..
i will be putting in a new expansion tank and cutoff switch this next week though: i used a tank and switch i have had in the garage for over 10 years
and it was used when i got it..an it appears to be going to give some problems: i'll probably go over one day next week and install a new tank and
switch.
heehaw
/ replaced jet pump. #7
Well, if you buy a GOOD submerisble pump they usually last a long time. Not one from Home Depot, Lowes, etc.
/ replaced jet pump. #8
I dont dissagree ;)
/ replaced jet pump. #9
As inefficient as pumps are, jet pumps are not nearly as efficient as a submersible pumps. I would always opt to go submersible first. Of course, if all you need the pump for is domestic water for showers, drinking etc., efficiency usually is not your primary concern. If you do any irrigating, it is.
/ replaced jet pump. #10
Amen to that! I would go submersible on the maintenance issue alone. I spent too many hours back in the day dinking around with shallow well and jet pumps keeping them running. The next great advance was the "new" (then) captive air tanks. No more waterlogged tanks, snifter valves, etc.
The drawback comes when you have to replace one of course.
Harry K
it will be interesting to see how long the pump last: Lowes was the only place i could get one at the time i needed it: i did have to change the low pressure cut off switch for a standard 30 on and 50 off switch: the low pressure one would kick off about every other day for some reason?? plenty of water etc: but it would just go off instead of kicking the pump on when the pressure got to 30psi: it was a used switch, so it could have been bad to begin with?? but all works great now.
heehaw
1043 (A60430)
1043 (A60430)
New/Unused Electric 3-Wheeler (A61166)
New/Unused...
RHINO G300' AUGER (A62130)
RHINO G300' AUGER...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
UNUSED WOLVERINE MCB-11-48W 48" HYD MINI 4N1 BKT (A62131)
UNUSED WOLVERINE...
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
