Replaced engine on my PT422
   / Replaced engine on my PT422 #21
In the PNW I had to recoat the inside of my fuel tank. bought some POR to do it worked great. One thing I found was my batter tray had some serious rust. was quite surprised. POR'd it as well.
   / Replaced engine on my PT422 #22
I think mine is:
-due to battery acid on bare metal
-due to paint loss
-due to battery vibration that wore the paint off
-due to kinda funky factory battery hold down strap that allowed the battery to bounce around.
I've since remedied the hold down strap. :laughing:
I think mine is:
-due to paint loss
Ok, I will bite. What did you do to the hold down strap?
   / Replaced engine on my PT422 #24
Bungee cords.... hahahaa, no.
I found the metal strap they provided with a skinny long bolt and nut that was accessed through one of the rear cutouts, well, that strap had a weird angle bent into it, did not fit the battery correctly, and, if I put it on and tightened the nut it would crack the battery case. I re-bent the strap and got a different bolt and nut and made it fit better. Put some rubber between the battery case and the metal strap, too. I've never had a machine that had a strap AROUND the battery. It's always either been over the top, or a bracket that grabs the bottom edge of the case. I may still change it around someday to a strap over the top.
   / Replaced engine on my PT422 #25
Now that you mention the battery strap around the battery, it is weird.
I added some rubber between the strap and the battery case for a better friction fit. It has never come loose, but then again, I haven't rolled my tractor yet.
All the best, Peter
   / Replaced engine on my PT422 #26
My strap actually vibrated a crack into the battery case. It was hard starting. I popped the covers on the battery, and there was no visible acid. Yikes! Found a crack right where the strap goes around.
Thanks for the reply. I might do something about this. I think a pad of some kitchen under it would help too. It gets bounced around a lot.
   / Replaced engine on my PT422 #28
My battery has 1/4 rubber pad as a base and back in the metal tray to reduce vibration.
   / Replaced engine on my PT422 #30
I don't know about Carl, but I got mine from the hardware store; 3/16" fiber reinforced rubber sheet, cut to size to go under and up one side of the battery.
All the best, Peter
2025 GPS Trailer (A56858)
2025 GPS Trailer...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
2017 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2017 KOMATSU...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2007 Ford F550 Superduty. 6.0 Powerstroke - 90k Miles (A56438)
2007 Ford F550...
