Renting Harley rake
/ Renting Harley rake #1
allthingsoutdoors
Kubota L3240
I am planning on renting a Harley rake to 1.5 acres of new yard. They have a hydraulic cylinder to angle the rake. How do I know if the oil in the cylinder will contaminate my hydraulic system? For all I know the last guy that rented it could have a 1960's tractor that has not had the hydraulic oil changed in 25 years.
Is there an easy way to check the oil quality?
Is it safe to just plug in the 2 hoses and go to work and not worry about it?
/ Renting Harley rake #2
I wouldn't worry about it. I know my tractor has almost 11 gallons of hydro fluid in it. Even if you ended up pulling in a couple of cups of contaminated fluid, it wouldn't make much of a difference.
JayC
/ Renting Harley rake #3
I agree with Jay4200.
But if you want to drain the hyd. cyl by removing the end couplings, then you probably could get a look at the oil at the same time.
Also could put your own cylinder on and use that.
I'd just use it and worry about something else. :)
Some before and after pics of using the Harley Rake would be great for us. :D
/ Renting Harley rake #4
This can be a problem when renting implements-kind of like kissing your sister on the lips:eek:
You can always remove the hoses and operate the cylinder manually to push out most of the fluid before you hook it to your machine.
2017 Ford F-250 4x4 Crew Cab Medical Service Truck (A61573)
2017 Ford F-250...
Generator (A61572)
Generator (A61572)
2022 EZ-GO ELITE...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2016 Deere 180G (A60462)
2016 Deere 180G...
