Removing rod guide help
/ Removing rod guide help #21
the other more common type will expose the inner ring after the suck-back ring is removed .....thinking you have this style Deere Runner.......just tap the gland in enough to make clearance for internal ring to clear and remove
I guess I did mention it....:eek:
Not sure if I did it correct or not, but I needed to fill the outer "suck back" ring with bondo in order to slide the guide back in the tube far enough to expose the second (internal) ring. It wouldn't just slide back in the tube without filling the groove. It may be a few days again before im able to work on it, but I will give it a shot. Why does the easiest of jobs always turn out to be the biggest pain in the butt?:laughing:
/ Removing rod guide help #23
Why do you think all those hyd shops are busy....:laughing:
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
2011 KUBOTA KX121-3ST SUPER SERIES EXCAVATOR (A64279)
2011 KUBOTA...
2012 FREIGHTLINER CASCADIA 125 6X4 T/ANDEM  SLEEPER TRUCK TRACTOR (A59911)
2012 FREIGHTLINER...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2022 EZ-GO ELITE...
2013 Mercedes-Benz GL450 AWD SUV (A61574)
2013 Mercedes-Benz...
