Removing rod guide help
/ Removing rod guide help #21
the other more common type will expose the inner ring after the suck-back ring is removed .....thinking you have this style Deere Runner.......just tap the gland in enough to make clearance for internal ring to clear and remove
I guess I did mention it....:eek:
Not sure if I did it correct or not, but I needed to fill the outer "suck back" ring with bondo in order to slide the guide back in the tube far enough to expose the second (internal) ring. It wouldn't just slide back in the tube without filling the groove. It may be a few days again before im able to work on it, but I will give it a shot. Why does the easiest of jobs always turn out to be the biggest pain in the butt?:laughing:
/ Removing rod guide help #23
Why do you think all those hyd shops are busy....:laughing:
Tube Line Manure Spreader Nitro 750 (A63688)
Tube Line Manure...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2022 EZ-GO ELITE...
2022 John Deere 616R Sprayer (A63111)
2022 John Deere...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2005 Peterbilt 378 Day Cab w/ Wetline 834826 (A62613)
2005 Peterbilt 378...
