Mowing Removing Chaff From Tractor Radiator
/ Removing Chaff From Tractor Radiator #21
I'll agree that you never want to dimenish the entering cfm of the radiator. But, after being in the hvac industry as a master contractor, service man, installer, and service manager of two companies, cfm is my business. Plus being raised on tractors for close to 61 years, this little cheap air filter that everyone buys for their house system and don't want to change it once in their lifetime when it should be changed monthly, will not diminish the cfm. It will only pick up the larger of the debri allowing the smaller stuff be caught by the screen. I've used this on 8n's, JD 5200, swathers, spray tractors, bobcats, and two backhoes. It's imperitive to keep close tabs on the temp gage wether you use the filter or not. This filter is only a light duty prefilter to give you a little more time in the field where the money is.
/ Removing Chaff From Tractor Radiator #22
Just a thought, but a small ac pancake style compressor (as mentioned) could probably be powered by a DC-AC inverter (plugged into your truck), as long as it has a sufficient wattage rating to run the air compressor. Run it just enough to fill up the compressor tank, and then let it "charge" the tank back up after you use it to blow out the radiator. They are not that expensive, and could come in handy for other uses as well.
/ Removing Chaff From Tractor Radiator #23
I have a 1000 watt power inverter that may not run a compressor. I'll try my small pancake tomorrow and give you guys test results.
/ Removing Chaff From Tractor Radiator #24
I use a gas leaf blower all the time. Works great.
/ Removing Chaff From Tractor Radiator #25
I keep a small brush in the tractor's storage compartment.
To make the brush most efficient, buy a 2 or 3 inch paint brush and cut the bristles down to about an inch. Then the bristles are stiff enough to do a good job removing the chaff from the grill and radiator.
I, too, used to keep a paint brush in the toolbox for that purpose, then I'd use the air-compressor, blowing from back to front, when I got back to the shop. A 2' blowgun from Northern Tool has a bend near the outlet end that worked just fine.
Kubota B21 TLB (A60462)
Kubota B21 TLB...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
