Removing cattails
/ Removing cattails #1
lhfarm
Central Indiana
NH TC40DA
I actually started this project a year ago, and quickly learned that I needed a dump trailer. I incorrectly posted my trailer trials here, but have gotten those fixed. This is a small pond and the water level is down, making it a great time to dig out the cattails.
I'm not using the hydraulics on the farm jeep - I need to add remotes!. I had a pump that lifts great, but the reservoir was too small. Purchased a reservoir and welded up a little frame. I can slide the pump in the bed of the jeep and reach the lever from the driver seat.
It is still time consuming - need a farm hand - with only one driver. Hop off the BH and move the trailer. Move the tractor as needed, then repark the jeep. The jeep needs power steering too! Parking close to the tractor is a challenge, but I am developing good arm muscles.
These pictures were taken yesterday and I've made some more progress. Also found that I'm going to need a hoe with a longer reach in a couple of spots. The plan is to remove as many cattails as possible before I have to have a real machine come in.
But it is working! Thanks for all the ideas and suggestions on getting the trailer to dump.
/ Removing cattails
Egon said:
The Jeep has character!!:D
It sure does. I spend more time in the jeep doing things than on the tractor. We are restoring (frame-off) a 1949 model. It will be mostly show, although my son insists it won't be a "trailer queen". The '47 may get some body work some day, but for now, she is just fine.
One of my favorite ads is "The "JEEP" is a Working Girl." You can see it at Vintage Farm Jeep Ads. Be sure to enlarge it so you can read the text.
/ Removing cattails #4
Why not just mow them down?
/ Removing cattails
They come back. Several years ago, I tried burning them during the winter. We had the best crop ever. The are like mangrove trees. They will fill in a pond over time. They collect sediment in their roots and build "fill" at a great rate.
The best solution is to increase the depth of the bank to they can't get a foot hold. I actually like the looks and a few are fine. But we will gain a great deal of surface area by doing the BH bit.
/ Removing cattails #6
Take a look in the powertrac forum. One of the posters made a neat rake for pulling them out, roots and all
/ Removing cattails
You right, I've already asked for detailed pictures. It might give me just the reach I need.
Thanks!
/ Removing cattails #8
You can import a couple of muskrats, they'll eat the roots out for you in no time, then just trap them and give them to a neighbor.
/ Removing cattails #9
Cool jeep!! I always wanted to restore one, but never got around to it.
/ Removing cattails #10
thanks for the link
I had a 64 jeep cj5, 74 cj7, my brother had a 48 willy's.
I am sorry i got rid of it! My fav was definately the cj5.
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
2022 EZ-GO ELITE...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
Ground Protection Mats (A64194)
Ground Protection...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
