Removing 72" belly mower while tractor on trailer
/ Removing 72" belly mower while tractor on trailer #1
StrmChzr
Spring Hill, KS
1995 JD 955
I very rarely need to trailer my 955 and I've actually never removed the 72" belly mower so I'm hoping for some advice/insight from those who have b/c I'm "stuck" on trailer. My belly mower is caught on the right fender well of trailer and I can't back off trailer. It seems I loaded trailer slightly right of center and every time I try backing up the belly mower kinda jams on the top of the trailers wheel well. I think easiest thing would be to take belly mower off if I can slide it out the side which it appears I can do.
Has anyone ever taken 72" belly mower off and removed it from the side? Was also thinking another option would be to jack the tractor up and try centering it better on trailer?
/ Removing 72" belly mower while tractor on trailer #2
Depends on the bed of the trailer.. a pic would help.
But better, IMO, to jack up and get square rather than remove the deck (especially for the first time routine)
/ Removing 72" belly mower while tractor on trailer #3
I agree with beenthere. A pic would help.
How hard would it be to remove the fender? Would that give you the clearance needed?
Is the deck raised to its highest position?
/ Removing 72" belly mower while tractor on trailer #4
Do you have a floor jack? Just lay a flat sheet of steel under the jack to make it easier to push around. Jack up the front and then the rear of the tractor and just slide it over a bit with the floor jack.
/ Removing 72" belly mower while tractor on trailer #5
Ya, move the tractor to center of trailer
Gents - thanks for the common sense insight! Tractor is off trailer and mid mount mower is OFF tractor until next spring... Having MMM off tractor will give me chance to give mower some long overdue TLC - gonna get deck sandblasted and then repaint it, as well as sharpen or replace blades and belt....
(4) ROADGUIDER QH100 235/80R16 TIRES (A60430)
(4) ROADGUIDER...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
KUBOTA ZG23F ZERO TURN LAWN MOWER (A60430)
KUBOTA ZG23F ZERO...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
SWICT 78" SKID STEER BUCKET (A60430)
SWICT 78" SKID...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
