Remove My Hazard Lights?????
/ Remove My Hazard Lights????? #1
MikeFLA
Central Florida
Kubota B7500
In a never ending search for just the right way for me to add rear lights to my B7500 I thought of this today.
I have owned this tractor for about a year and I have never used my flashers. Nor do I think I ever will. I was thinking of removing them and installing the round tractor lights they sell at TSC.
I could hopefully use the same switch on the dash. I'd obviously have to figure a way to change it from flasher to on/off.
Any thoughts?
/ Remove My Hazard Lights????? #2
mike
if you can follow the wires from the switch you should find a silver canister the flashing relay. just remove the wires from the relay and splits them together. there should only be two wires on it. hope this helps. good luck
/ Remove My Hazard Lights????? #3
Mike
Two things to think about:
one is that you may void the warranty by doing that now
The other thing if you do it make sure that the wires and the switch are the corrct size for the load of the lights
Thanks for the feedback guys...
Sounds like bypassing the relay would solve that problem.
I had not thought about the warranty. Doing something that may void the warranty is not an option.
I did think about amperage draw with 55 watt lights, but I have yet to determine if the wiring can handle it.
/ Remove My Hazard Lights????? #5
Mike,
Did you know that there is a prewired 15 amp circuit for work lights already installed on the B7500. I was getting real creative trying to figure out how to wire mine when I stumbled across that circuit. It made for a very simple installation.
Greg
Greg,
I assume that the pre-wire works off the front headlights switch...True?
/ Remove My Hazard Lights????? #7
Mike,
One just never knows what he MIGHT need in the future...
I don't expect to need my flashers either...but would not remove them...just in case...
If your luck is like mine, the day after they came off I would find the need to use them. /forums/images/graemlins/tongue.gif
/ Remove My Hazard Lights????? #8
Mike,
No. It is an independent circuit. I wired an inline switch on mine. The stub out is located behind the drivers seat on the right hand side and has a female quick disconnect ready to go. It is color coded red with a blue stripe. There is a black ground wire available as well. I am running 2- 55 watt driving lights and one tractor light (35 watt?) on this circuit. This makes for a very easy install.
Greg
/ Remove My Hazard Lights????? #9
I mounted 2 Blazer lights on the rops of my 7500. Check it out.
/ Remove My Hazard Lights????? #10
i use my flashers all the time, when i am on the road removing snow, from my drive and at the corner where my mail box is located, course don't beleive that would be a condition u would be under /forums/images/graemlins/cool.gif just make sure that the flasher circuit can be used for lights, not too much draw.
/ Remove My Hazard Lights????? #11
BX2200 also has wiring for lights under the driver's seat with connectors already attached ... for those that are interested.
I would use the pre-wired circuit and add a switch; many have put the lights on the ROPS and mounted the inline switch on the ROPS as well so you don't deface the instrument panel.
I would not remove the hazard lights ... but that's just me.
Just my 2c.
/ Remove My Hazard Lights????? #12
WDN,
Regarding the wiring on the bx2200; is the wire just a hot feed off of the fuse block? Also, would you know what the alternators' rated output is?
thanks,
DaveL
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2022 TrailMaster Gas Cart, (A61574)
2022 TrailMaster...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
2025 SAWYER 85BP20 20FT T/A ENCLOSED BUMPER PULL TRAILER (A59912)
2025 SAWYER 85BP20...
