Remove Key While Running?
/ Remove Key While Running? #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
I just learned tonight while brush hogging that I can remove the key from the ignition in the "run" position while my tractor is running. I found out because somewhere along the line while hogging the key must have been pulled out by a tree branch or something. I went to shut the machine down...and there was no key! Luckily I found the key on the floor and was able to shut her down. Now I have the key on a lanyard and start the machine with it and then put it around my neck so I know where it is when it is time to turn off.
I assume this is NOT normal, right?
ac
/ Remove Key While Running? #2
ac
LOL really? Of course not... The switch is messed up, key should def not come out.
/ Remove Key While Running? #3
Got a key for my truck that you can pull out and it stays running. Just wore a lot. A new key you can't do the same with it.:)
/ Remove Key While Running? #4
I'll have to check my Kubota, but I'm pretty sure I can turn off the ignition and remove the key and the engine will continue to run. Also, I know I can shut off the engine without turning the key off. I have a manual, spring loaded, fuel cutoff lever to stop the engine. I've been told when I bought it that if the key is on, the hour meter will run even if the engine is not running.
Also, I tie a bright red ribbon to the key ring in case I drop the key. I use red because I haven't found international orange ribbon.
/ Remove Key While Running? #5
Kinda funny I just noticed the same thing last week! I thought it was weird. Tho its not a big deal is it falls out as I keep mine on a lanyard that my battery cutoff key is on the other end. I ment to try my spair key that a new key, but I just have not gotten around to it.
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
Yale 5K Forklift (A63689)
Yale 5K Forklift...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
