Remove Key While Running?
/ Remove Key While Running? #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
I just learned tonight while brush hogging that I can remove the key from the ignition in the "run" position while my tractor is running. I found out because somewhere along the line while hogging the key must have been pulled out by a tree branch or something. I went to shut the machine down...and there was no key! Luckily I found the key on the floor and was able to shut her down. Now I have the key on a lanyard and start the machine with it and then put it around my neck so I know where it is when it is time to turn off.
I assume this is NOT normal, right?
ac
/ Remove Key While Running? #2
ac
LOL really? Of course not... The switch is messed up, key should def not come out.
/ Remove Key While Running? #3
Got a key for my truck that you can pull out and it stays running. Just wore a lot. A new key you can't do the same with it.:)
/ Remove Key While Running? #4
I'll have to check my Kubota, but I'm pretty sure I can turn off the ignition and remove the key and the engine will continue to run. Also, I know I can shut off the engine without turning the key off. I have a manual, spring loaded, fuel cutoff lever to stop the engine. I've been told when I bought it that if the key is on, the hour meter will run even if the engine is not running.
Also, I tie a bright red ribbon to the key ring in case I drop the key. I use red because I haven't found international orange ribbon.
/ Remove Key While Running? #5
Kinda funny I just noticed the same thing last week! I thought it was weird. Tho its not a big deal is it falls out as I keep mine on a lanyard that my battery cutoff key is on the other end. I ment to try my spair key that a new key, but I just have not gotten around to it.
1977 Dodge B10 Cargo Van (A66736)
1977 Dodge B10...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A66736)
2008 Ford F-250...
Unused 2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
x (A68191)
x (A68191)
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
