Remote hookup question
/ Remote hookup question #1
twinjayhawks
NE of Tulsa, OK
Century 3045
I have never used my remote hookup on my tractor. Do I need to use both connectors... One out and one return? Or are there 2 remote hookups?
I only have the one control at the right of the seat to control the remote.
I want to purchase a cement mixer that can dump from the remote. Thanks for the help.
Pictures from my Century 3045
/ Remote hookup question #2
Most cement mixers have SA (single acting) cylinders, so they have only one hose. You can use that with your remote by only plugging into one coupler.
Does it matter which connector I use for the cement mixer?
For some implements will I have to use both connectors?
/ Remote hookup question #4
No-one will dump the mixer when the lever is pushed, and one will dump when the lever is pulled-It's up to you how you want it to work.
Yes, if it has a DA (dual acting) cylinder on it that has two hoses.
kennyd, Thanks for the information.
I would like to add an Hydraulic top Link. Will there be any problem using this with my setup?
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2024 Texoma 16ft. T/A Equipment Trailer (A64194)
2024 Texoma 16ft...
CATERPILLAR CB66B DOUBLE DRUM ROLLER (A65053)
CATERPILLAR CB66B...
Craftsman 16in Variable Speed Scroll Saw (A64553)
Craftsman 16in...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
