Relief valve
   / Relief valve #1
Degolyerent
I have a Takeuchi tb135 and I installed a hydraulic thumb and used the auxiliary circuit. My question is does this circuit have a built in relief valve or do I need to add one? I busted a hose because of pressure but it was fairly used and had bad spot but it got me thinking about the relief valve.
John
   / Relief valve #2
You need to install a relief valve (return to the reservoir) in the thumb return line set to about 1,800 psig.
   / Relief valve
Thanks Bob, is there a particular inline relief valve you can reccomend?
Thanks
John
   / Relief valve #4
if your unit came pre packaged with an aux valve, the aux valve might have a pressure relief built into it.
if you bought your own valve and tied that into the hydrualics. then ya most likely looking at a 3rd party pressure relief valve. pending on your 3rd party valve, you might have option in install a relief valve into the valve itself some place and you just need to remove a bolt/cap to gain access to were pressure relief goes.
might be worth calling manufacture and double check with them. there website doesn't give much for info.
Takeuchi US | Contact | Compact Track Loaders, Wheel Loaders, Excavators
   / Relief valve #6
Thanks
John
As was mentioned before, check with Takeuchi to see if there is a built in relief valve or port relief, but in all likelihood since you blew a hose - there isn't.
The valve that JJ recommended is a good choice, it's also the one I used when I installed my thumb.
   / Relief valve
Hey, I really appreciate the help y'all !! I will get it done. I would guess that it mounts inline with the relief side going to a Tee into tank?
John
   / Relief valve #8
John
Correct. And remember it goes in the thumb return line. :)
   / Relief valve
Thanks Bob and JJ, y'all are the greatest!!!
   / Relief valve #10
And don't forget to set the relief setting to about 1,900 psig. Well below the system relief. :thumbsup:
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
SHOP CART (A53843)
SHOP CART (A53843)
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
