regenerative hydraulics for a log splitter?
/ regenerative hydraulics for a log splitter? #1
Cord
Richfield, Wi
Resident Architect
Do any members know how to design a regenerative hydraulic system? It would need to be pressure based system which would automatically unload once the cylinder encountered the work. The unload pressure would be 2-300 psi. The thing that is tripping me up is that the regenerative system can not be based in the control valve, it needs to a external valve. Things like hose routing and part numbers would be needed.
This is the autocycle valve that I was planning on using. You can find the plumbing diagram on page 6. http://www.princehyd.com/LinkClick.aspx?link=products/valves/AutoCycleManual.pdf
/ regenerative hydraulics for a log splitter? #2
It's an interesting idea, but would would like to know more about how you want the splitter to work in its cycle with this.
Well, that could be a problem. I don't know enough about hydraulic design to know if there will be a problem or not. Basically, my desire is to have the ram come forward as a regenerative circuit until it starts to build pressure. Then a pressure sensitive check valve will close and the circuit will function normally. I know that this is very do-able for a standard log splitter. I don't know how it will work with the autocyle valve. Even for a standard log splitter, I don't know what the circuiting or components are, I just know that it's do-able.
/ regenerative hydraulics for a log splitter? #4
Unless I misunderstand the idea..
Fast ram extension till it hits resistance?
Two stage pump.
Haldex two stage pump
A regenerative circuit ties the piston side of the ram together with the rod side so the actual piston speed is greater than what the pump output is. Some loader valves have a regenerative circuit on the bucket dump. This lets the bucket roll very quickly.
2007 Mercedes-Benz C230 Sedan (A64557)
2007 Mercedes-Benz...
2007 Top Brand Deck Over Trailer, 18'+3' Dovetail (A62679)
2007 Top Brand...
Frontier 10ft. 3 Point Disc (A65640)
Frontier 10ft. 3...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
New/Unused Wolverine 84in Quick Attach Rock Bucket (A65583)
New/Unused...
