Regeneration Valve
/ Regeneration Valve #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
I have a Prince MB series 8 GPM valve on my Log Splitter. I have that one as in that GPM range it is the only one SC has with PB capability. I am confused by the jargon around Regen valves. I see some on the net that just go in the output line of the MB. If I did such what would be the effect on performance? My cylinder is a 4 x 24 and cycle time is slow, power is way more than what I need for most logs except knotty (burn them whole). Any ideas on the proper brand/model for this application?
Ron
/ Regeneration Valve #2
Take a look at this fast extend log splitter valve by Prince. LSR-3060
It will take about 4 GPM and make it into 25 GPM for fast extend.
Model LS3060 Rapid Extend Log Splitter.
If your tractor puts out 8 GPM, then run the tractor at half speed to produce 4 GPM.
Thanks JJ but I looked at that already. It does not provide Power Beyond capability. Pressure is not my problem, its the cycle time with that big cylinder and only 7 GPM output. I even oversized the hoses to reduce the friction factor.
Ron
/ Regeneration Valve #5
I am pretty sure your BX does not have 7gpm to work with, the posted specs online show "total flow" as 6.3gpm, but I think some of that is directed to the steering through a priority valve and unavailable in the PB lines.
Edit: Post #7 in this thread states that 1.8gpm goes to the steering, so you only have about 4gpm left over for your splitter.
Unfortunately combining the numbers is a marketing tactic...
How about this one .
It is an auto valve with PB.
1 SPOOL PRINCE AUTO CYCLE LOG SPLITTER VALVE W/PB
JJ,
If my operation was for production rather than personal I would go that way. I would never try to do high production work with a BX anyway; so I would have a lot more GPM to start with. From discussions posted here on TBN and discussions with the SC Tech guys seems the sage advice is to select a Max GPM valve rating close to your available GPM at the P port. They say too large a port can cause erratic action. From advertisements I thought the Regen add on unit may be my answer. I am not hearing any positive feed back on that idea so guess it is not of any value to pursue. Thanks anyway guys.
Ron
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
2025 16in Tooth Bucket Mini Excavator Attachment (A66734)
2025 16in Tooth...
2018 MAGUNS  VACUUM/POWER WASHER TRAILER (A67714)
2018 MAGUNS...
2005 CTS BELLY DUMP (A67714)
2005 CTS BELLY...
JOHN DEERE 6420 TRACTOR (A65054)
JOHN DEERE 6420...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
