Regarding 3rd function valve sticking
/ Regarding 3rd function valve sticking #1
brocas
I had my dealer install the 3rd function valve on my L3940 to operate a grapple:). This was based on the advice of a lot of people that claimed (guessed perhaps:confused2:) that its beter than a selector valve.
When I first tried it with my grapple, the speed was too high (to the point where movements were so sudden it looked like the grapple would fly off!).
I think the problem was amplified because the grapple has only a single small cylinder. So, I decided to add flow control valves to restrict the flow and slow the thing down.
The flow control valves definetely control the speed. But, when the speed is reduced to a level that I think is "right", the dreaded 3rd function valve sticking shows up.
I thought that this sticking was somehow related to the flow control valves but from previous thread looks like the 3rd function valve may have issues with sticking.
I still leave the flow control valves on and turn then until there is no sticking but the resulting speed is still too high (but much better than with no control at all).
I was really hoping that the 3rd function valve would work for me, but at least in this applicaation for me, not only do I not get "feathering" but I also get sudden movements, so very little to no control.
Needless to say, I'm looking for other options.
I hope this helps someone thinking of addiong this valve, it may not work well for you application.
/ Regarding 3rd function valve sticking #2
Man this sucks. You are the third person in the last few days to mention this. I was looking foward to the third function valve. It seemed better than the other brands as you could use it at the same time with the other loader functions.
Yes I think this valve is really not suited to operate a grapple. On/OFF is simply too fast, I think even with two large cylinders. I suspected this, my plan B was to add the flow control valves (even though this is not an ideal solution since the releif valve is dumping the "extra" flow). But with the valve sticking, this is no go.
Too bad I'm not a hydraulics expert because I suspect there is a simple solution.
What I would like is a HI/LOW switch to control hydraulic fluid flow. This would be great for all the hydraulics when you want to switch from speed to precision. I cant believe this would be that hard to accomplish :licking:.
/ Regarding 3rd function valve sticking #4
What about putting a reducer on the hydraulic line. The would slow the flow down and that would slow down the cylinder.
/ Regarding 3rd function valve sticking #5
What size hoses are you using?
I wonder if moving the flow control near the grapple would help?
/ Regarding 3rd function valve sticking #6
Other than my trigger switch failing I do not have any problems with the WR Long valve on the L3130, think I would try that one, and I think it may be cheaper.
David Kb7uns
/ Regarding 3rd function valve sticking #7
I also have the WR Long. In fact, when I bought the L3240, the Kubota dealer recommended it over the factory Third Function. Mine is used solely for a Construction Attachments grapple and there have been no problems at all. I liked it enough I had them move it to my newer Kubota.
/ Regarding 3rd function valve sticking #8
With a high volume valve, and a small cyl, you can expect fast action. About the only way to decrease the speed is to reduce volume by restrictors, diverting some of the flow, and use of the feather ability. . The solenoid valve is full on or or off unless you want to add those proportional valves that only provide as much volume as needed.
Is your needle valve in front of the solenoid valve.
Option, install a larger cyl for more down force, and slower speed of activation.
/ Regarding 3rd function valve sticking #9
A 2 in cyl ,1 in rod, 10 GPM, = 12.3 ips ext, and 16.3 ips retract.
-----------------------5 GPM = 6.1 ips extend---------8.2 retract ips
A 3 in cyl, 1 in rod, 10 GPM, = 5.4 ips extend----------------6.1ips retract
-----------------------5 GPM = 2.7 ips extend----------------3.1 ips retract
So volume and cyl size will affect the grapple speed.
/ Regarding 3rd function valve sticking #10
With the two large cylinders (my grapple) the flow rate seemed to work well, not to fast not to slow just right.
I really hope kubota get this 3rd valve thing figured out.
/ Regarding 3rd function valve sticking #11
It does not make sense that they would offer a product that is basicly non-functional like that. I can see why you guys are upset. After reading this post I am glad (and very lucky) that I added a second a manual spool valve for my grapple control. I can feather the grapple just like the FEL. If any of you want to do the same there are several threads on how. Search teg or me or 3rd function.
The flow control valves (they are restictors that restrict flow in on direction) are after the solenoid. I dont think they could be placed before the solenoid as I think the 3rd function valve is plumbed from the FEL PB port and I'm also guessing the solenoid valve also has PB to contiue the circuit to the 3PH.
I dont think adding a second cylinder is an option (its a small grapple) and a bigger cylinder I dont think would be enough. Honestly I dont think on/off with such large flow is suitable for rthis application. It not just fast, its jolting fast.
Full feathering would be nice but I would settle for 2 speed. In fact even for the FEL that has the feathering, I think a HI/LOW selection would be really nice for really precise movement.
I am seriously considering adding this HI/LOW function not just for the grapple but for the FEL too.
I Imagine adding a "speed" control valve righ after the pump and before the FEL block. The speed valve would divert some of the flow back to the sump in one setting, and full flow in the other setting. Some details would have to be worked out on how the speed valve would be controlled.
That's what the flow control valves are. They restict flow in one direction. They do exactly what is expected. The problem is, if the flow is restricted to a level that gives good speed, the 3rd function valve starts sticking. It is possible that the 3rd function valve (its a solenoid valve) doesnt like too much restriction (needs a certain minimum flow to operate properly).
The kubota 3rd also seems to work fine. The problem I have is the flow is too high. When I try using restrictors to reduce the flow, the valve sticks.
Perhapps the solenoid valve needs some minimum flow to operate properly, or perhapps its a crappy valve.
I was well aware of this. Like I said, plan B was to restrict the flow. Your calculations are just for cylinder speed, not even accounting for the lever amplifications.
I cannot describe how fast the grapple moves. One touch of the button and the grapple flies and stops with a big shock, totally unusable and nerve shattering at full flow.
I wouldnt say its totally non functional, but I would say its non functional with my grapple.
I hear you about adding a spool valve, but the attraction of the 3rd function is that there is only one lever. You can raise, curl, and clamp at the same time with a single hand. You gotta admit, that's pretty sexy.
/ Regarding 3rd function valve sticking #19
...or perhaps its a crappy valve.
Oh no way... :rolleyes:
How long have you had this valve? If it's not too long ago and it's causing the sticking problem... I would see what the dealer says about fixing their problem valve. That just should not happen.
Not sure if going to 1/4" lines would help or not...
/ Regarding 3rd function valve sticking #20
Do you have a picture of your grapple set up?
If the geometry is not correct, you will have fast speed. Do you need high volume of fluid for normal FEL operations? You could run the engine at 1/4 speed, decreasing the volume by 4 . If you had 12 GPM, you now have 3 GPM.
This is a priority flow divider valve, the priority circuit uses 3 GPM, and the rest can go to tank, or to another valve.
Surplus Center - 3/30 GPM PRINCE PRIORITY FLOW DIVIDER W/RELIEF
What appears to have happen here is a flaw in the design of the grapple geometry, the cyl used and the valve used. This is where the engineers are supposed to figure all this out before it gets installed. If it doesn't work, the technician then comes in and fixes it.
2022 CATERPILLAR 349 EXCAVATOR (A65053)
2022 CATERPILLAR...
PORTA POTTY (A68842)
2014 FREIGHTLINER CASCADIA (A67714)
2014 FREIGHTLINER...
2017 HINO 338 REFRIGERATED 26FT CDL REQUIRED BOX TRUCK (A69167)
2017 HINO 338...
2012 COMPTANK CORP. 130BBL FIBERGLASS ACID TRAILER (A67714)
2012 COMPTANK...
2011 FORD CROWN VICTORIA (A66091)
2011 FORD CROWN...
